Atf for 904/999 transmission
Dartfreak75
Restore it, Dont part it!
Virginia
I have been using the mopar atf+4 in my 999 torqueflite. It is all original only thing I did was take it apart clean the valve body and install a shift kit. Im running a boss hogg converter. Im about to replace my transmission pan gasket for the 4th time at 8 dollars a quart atf4 is getting really expensive can I use the cheaper dextron stuff or should i stick to atf4?
I had the same question on a 904 and after researching the web, found out type F works and you can blend it with ATF 3/4 to get crisper or smoother shifts. More ATF 3 = smooth, more Type F = crisp.
Of just use the stuff labled ATF. if you look at the bottle you will see it covers dextron 3 which is the original fluid for chrysler automatics until the overdrive unit came out.
If you are dropping the pan just for a gasket change and if the fluid doesn't have many miles on it, why replace it with new. Drain it into a clean pan and put it back in.
For extreme duty type F is recommended. I used it in all my mopars with higher stall converters due to heat from converter slippage. Cheaper the race fluid.
Type F does firm up the shifts. Look on the back of a bottle of B&M Trick Shift. It says something like "Compatible woth Ford Type F", or some such. That's what it is. Where in the world did you get the ATF+4 recommendation?
I have to add more because alot has leaked out. I recovered 3 quarts from it. So I gotta buy something either way
I can't remember Google i think I wanted to use mopar brand atf and atf4 was what I found that was compatible on the mopar brand
I haven't had an automatic without a drain plug in the pan. The first thing I do when changing the fluid and filter is put a drain plug in the pan.
Most of the time I just buy a nice cast aluminum pan.
10w motor oil.
Yep, I usually add a quart to the type F fluid I use
Wait are yall being serious? I thought he was being facetious
Used F in my mopars and chevies for decades. See no reason to change now.
Just as an aside, I have heard racers using hydraulic system fluid, with great success. But that is usually for cars with LOTS of power, and LOTS of stall speed.
I've known guy's using 10w or 20w oil but they were in powerglides. 8 sec rides. I really don't know as I haven't tried it myself, but they did it in fast cars and drove them on the street.
Check with Napa - they regularly run sales on their house brand Type F and Dex transmission fluids. If I recall, it was like $3.50/qt (about half off) a few months. I bought a bunch. I usually end up using whatever I've got on the shelf. It's not worth overthinking it.
Just googled trans fluid (F) at Walmart. Considering that "name brand" type F is $13-14 a quart, and Walmart house brand is $18.50 a GALLON, I know what I am gonna try next time.
The 18 dollar stuff at Walmart is dextron 3 that's why I was wondering if its ok to run dextron
