There are several advantages with using an early 360 block in place of a 340. The main webs in the early 360 are extra beefy, and the lifter bores aren’t countersunk. And the cylinder walls are thick to the point of being nearly Siamesed.
Simply because I wanted to !Very cool work! I'm trying to figure out why you would do it, but, impressive.
Everyone is on a different pathAgreed, but, if you're looking for all out performance, why not put a billet stroker 360 crank in that block and get some extra cubes too?
Yep, it's fun just to build odd stuff and make things work..Simply because I wanted to !
Aren’t the rear seals also different between 340/360?
This was a BEEFY BLOCK and thanks for selling it to me ###There are several advantages with using an early 360 block in place of a 340. The main webs in the early 360 are extra beefy, and the lifter bores aren’t countersunk. And the cylinder walls are thick to the point of being nearly Siamesed.
I built a strong LA using parts I have horted up ### and because I could .True! Build something slightly off and people start instantly with “Why didn’t you……”
I don’t get it. It’s pretty obvious he wanted a 340 so he went this route.
Well a member and machine shop owner and operator finished up on another engine project
For me last week . I basically used misc nos parts to piece it together.
73 (360) block 40 over
Std bore (Lite weight) Trw domes
H beam 6.123 rods
68 (340) crank std-std
This is an unorthodox build by todays standards but ###
Different strokes for different folks !!!!
What holds the spacers in the block as I don't see any tabs on them. I like the idea of destroking a 360 to get a 340. It's sad that the aftermarket doesn't offer a 360 crank with a 340 stroke, when it comes to the mopar the aftermarket is lacking. How long was it before you could get a 440 crank with 400 main bearing journal size? If there was a 3.480" stroker crankshaft, you could bore a 318 0.030", use factory rods and off the shelf replacement pistons ( I think the compression height is 1.725" ) and you'd have a 340. I'm not sure about the compression height of the pistons I do remember looking them up, I believe that they are speed pros.
I think for most whats attractive about the 340 isn't the total cubic inches but the bore to stroke ratio and the reputation for performance associated with the original 340. It's like having a 302 chevy vs a 305 chevy. similar in cubic inch but different reputations.What holds the spacers in the block as I don't see any tabs on them. I like the idea of destroking a 360 to get a 340. It's sad that the aftermarket doesn't offer a 360 crank with a 340 stroke, when it comes to the mopar the aftermarket is lacking. How long was it before you could get a 440 crank with 400 main bearing journal size? If there was a 3.480" stroker crankshaft, you could bore a 318 0.030", use factory rods and off the shelf replacement pistons ( I think the compression height is 1.725" ) and you'd have a 340. I'm not sure about the compression height of the pistons I do remember looking them up, I believe that they are speed pros.
That’s it right there! And the block he used is also nearly as strong as an X block. It’s good to see this one go from what it was dismantled from to what it is now. It was a 1973 W300, Windsor plant engine that was used on a mine as a powder truck. And like he says, it saves the 340 for the restoration crowd.
So what static compression are you shootin for? Don't forget, We still have this lock thing for you ridin around in Kitty's car. lol
Wasn't trying to rush on that. We can meet before that if you need it. No problem at all.Yes Sir - your slant will be pulled soon and we will meet up in Macon
The 340 is just somehow a magical combination in stock form. Totally beat anything's *** in a similarly weighted vehicle with any factory stock small block and some big blocks. There's a reason they were legends.I think for most whats attractive about the 340 isn't the total cubic inches but the bore to stroke ratio and the reputation for performance associated with the original 340. It's like having a 302 chevy vs a 305 chevy. similar in cubic inch but different reputations.
