NGK Plug recomendation
roccodart440
NGK seems to have two heat ranges for the 440, a (4) and a (5).
They are the XR4 and the XR5.
Anyone have any experience with these or any recommendations?
Engine is a 440, 602hp 10.5:1, 260@.050, .650, 112LSA, eddy RPm heads
Edelbrock Perf RPM head requires a 14mm x 3/4" reach plug. XR4 & 5 are short reach plugs. 4 is hotter than 5. 10.5 compression with 600 hp should probably be in a 5 or 6 heat range depending on fuel type and quality. Maybe colder yet? Some NGK numbers to look at would be FR, or GR series, R5671A-_, or R5672A-_ series. 5/8" hex would be recommended for headers. Not all of the race series plugs are available in -6 heat range. What plugs were used to dyno at 602hp? May want to follow with the same.
Picture is a BKR6E posted
10.5 - 1 383/432 Eddy E Street Heads 75cc
I called NGK and asked what plug
Anyways
I tried the 5 at one point and the threads on the plug showed color four/five threads down , to hot
