Yes and thanks for reminding me....I was going to replace the throw out bearing anyway but my clutch and pressure plate is newAnd be aware this requires a clutch change also due to being 18 spline, vs 23. This will add to the expense up front. I look forward to learning if he still sells the conversion gear sets.
I answered your other post. I had 2 cars with the Tremic and one with the passion 4 speed OD.
I would do the 4 speed OD again over the 5 speed.Just my 2 cents.
In my case, it is a true 340 4 speed car, I have no interest in butchering the floor. I would absolutely do it to a non performance model car, the driveability and utility of the Tremec would be awesome.Curious what makes you favor the OD over the Tremecs? Difficulty of install not worth the extra gear? Something else?
I appreciate your viewpoint, it is likely the right answer, I cant get my head there though.My car is a real 360 4 speed car and I have for years waffled over putting a modern trans in it because I didn't want to cut the floor. In the end, it comes down to driving enjoyment and not cutting the floor is pointless if I'm not going to sell the car. So I am going T56/TR6060.
Tremecs weren't the greatest shifting. Notchy and weren't able to power shift without grinding or not going into gear at all. I had the first one in a Duster in 2000 then 2002 in a B body. I did have to do some surgery to install them,not much just had to remove a few bosses in the case to clear the floor.Now things may be different 20+ years later.Both cars I had to have driveshafts made but can't remember if I had too or if I wanted too.
Thanks for this response, these are exactly the concerns I, and likely others, had feared.I have a 340 with a iron 833od gearbox 3.55 LS 8 3/4 and 14 inch tires. And I hate it. first gear is too low second gear is too far from first and 4th gear is noisy. I am planning to swap back in a non OD 833, and maybe add a gear vender unit. The 833od were designed to be for fuel efficiency behind slant six's and not for "fun".
Likely rarely use the 6th gear but I could blast down the highway at 100mph at 2500 rpm with 4.10 gears
I always thought that a stout small block or stroker in front of it with 400+lb-ft of torque would take care of the big 1-2 split.
I haven't called passion yet but they advertise the transmission at $3,600. No shipping as I will pick it upCurious what makes you favor the OD over the Tremecs? Difficulty of install not worth the extra gear? Something else?
Ok then;Ahhhhhh, come on now!
AND the title of the thread is;Any and all thoughts are welcomed
Opinions on 4-speed with OD
See; that is a thought and/or an opinion.The following are my opinions based on 4 years of trying to be happy with it.
You should get your head out of your *** & out of the calculators and actually do some wrenching.But since you asked; and I assume that you're not too good at math, or are just lazy, or vindictive, grumpy, or just not getting any;
I run the Passon hemi overdrive.
4.30
28" tire
340 stroker (418)
I received a gear set early this year because of my stupidity but that is a whole other story.
I did not have any issues with Jamie Passon he was very helpful. I did have to wait awhile because of covid shutdowns :-(
I have been working on a big block stroker combo and picked up a tr6060 from an 11 challenger and converted it to a t56 magnum. OD drops to .50 Doing some digging I would be same rpm area as the 11 challenger if I run 28" tire and 4.10 gears.
Would I do the passon hemi OD again? It has its place and I have no complaints with it. Bolt in and drive (18 spline input)
Why the t56?
I have a habit of looking at things and wanting the challenge. Big block and double overdrive and possibly some fuel economy sucked me in. Likely rarely use the 6th gear but I could blast down the highway at 100mph at 2500 rpm with 4.10 gears
Here is an rpm calculator that I have played with over the years.
Speed/Tire/RPM calculator
What do you think of the gear spread with the Passon OD gear set? Compared to a stock gear set?
I know someone that had one behind a 472 Hemi and didn't like the spread. His opinion.
