Johnny71dusty
Anyone know what size bolts should hold down the choke thing to the exhaust manifold ? I snapped bolts off on my old one and i got a new device bur need some bolts for it but nothing I have fits so thought I'd ask .
Brand New manifold has same thing . One hole is smaller ( closer to carb ) and has a stud on it and one closet to head is a bolt .Then someone has messed with it.
In that case it's one that only has one bolt that holds it on and the other side has a locating tab that goes in the other hole.Brand New manifold has same thing . One hole is smaller ( closer to carb ) and has a stud on it and one closet to head is a bolt .
Bigger problem for the '70-'72 exhaust manifolds is the gasket that goes between the choke cup and the manifold itself. The V8 gasket is available, but it's not the same as the Slant-6 gasket, which is not.
