Fit B body pedals in A body.
No, they won't bolt in.
Same for the reverse as in A-Body pedals in a B-Body.
If you are good at fabricating, you can make anything work...
You are better off trading the B-Body pedal set for A-Body ones that will bolt up.
FYI, the B-Body ones are worth more money depending on the year of course...
@Dartnut Thats what I was thinking. Nothing a sawzall and a welder can’t fix! HA HA HA
But that’s probably more of a PIA than anything making it more or less not a great thing to do.
@GTX JOHN What year B body pedals do you have?
You need to specify what A-bodies and what B-bodies and what pedals you're talking about. Do you mean the '62-'65 B-body accelerator…? The '66-'67 B-body accelerator? Brake pedals, clutch pedals? Into…a '60-'66 A-body, a '67-'74 A-body, a '75-'76 A-body?
I put a '62-'65 B-body accelerator in my '62 Lancer.
That’s what I was wondering.
Hey slantsixDan, at the threat of a thread hijacking…..
Will B body 72-74 4 spd pedal work in a 78-79 B body?
The Op is referring to a set of pedals he has in a separate for sale ad.
The top part appears to be from a 66/7 B body but the pedal arms themselves are NOT B body.
It's a cobbled set and the part that is from a 66/7 B body is cut on the front so it's no longer of any use even for a 66/7 B body and its missing pieces.
Seems to me you know more than I do about this. I’ve never done pedal swaps before. I’ve only had 1 Duster and 1 E body ‘Cuda with pedals and they never left the car.
