BillGrissom
The exhaust manifold is probably worth $100 since they crack, especially if the washers aren't correct and oriented properly. New ones cost >$200. If it has the inner pulley on the crank damper (large center hole to fit over timing cover snout), used on AC cars, that should be valuable to someone adding AC (I needed one).
