^^^^^^^^^^^^^^^ THis^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Yes- measure the inner diameter (the friction surface), that will tell you the size.
It is either a 9" or 10" Unless a previous owner changed somethin
Alright, thanks.^^Yes- measure the inner diameter (the friction surface), that will tell you the size.
Im not planning on using these drums i just want to know if i have 10 inch spindles so i can buy wilwood disc conversion.The good news is at 10.4 on a 10", looking at the thickness in the pic, you have plenty of room 0.20 to have these turned and don't need to buy drums yet.
A photo of the spindle will settle that issue. Also, the 9" brakes use A1 and A4 bearings......The 10" brakes use A2 and A6 bearings.Im not planning on using these drums i just want to know if i have 10 inch spindles so i can buy wilwood disc conversion.
Ill grab a photo when i get home.A photo of the spindle will settle that issue. Also, the 9" brakes use A1 and A4 bearings......The 10" brakes use A2 and A6 bearings.
How much? What do people want them for?Those drums are worth pawning off even if they need turning if they are 10's.
Hmmm good to know.You'd have to get them mic'd and sell them as turntable as they are not that easy to find serviceable or new l. The come up for sale new from CHINA time to time but they seem to be limited runs.
Hey, can somwone let me know the drum size.
From one side to another in the smallwr ring its 10.4 ish so does it round down to a 10 inch drum?
View attachment 1716011908Couldn’t find mine so a copied a pic from the web. I think I loaned it out.
Just for future reference the spindles pictured are 10 inch spindles, 9 inch have the upper ball joint stud boss twisted 90 degrees.Hey, can somwone let me know the drum size.
Ok thanks.Just for future reference the spindles pictured are 10 inch spindles, 9 inch have the upper ball joint stud boss twisted 90 degrees.
Be aware that the Wilwood hub is larger, and many factory wheels won't fit. There's several threads on the forum you can research that detail this. As long as you know what you're getting going in, you can plan for a satisfactory outcome. Several people have made the purchase and found out the hard way they needed new wheels.Im not planning on using these drums i just want to know if i have 10 inch spindles so i can buy wilwood disc conversion.
Yeah im going to conver to the larger bolt pattern, looking at american racing wheels.Be aware that the Wilwood hub is larger, and many factory wheels won't fit. There's several threads on the forum you can research that detail this. As long as you know what you're getting going in, you can plan for a satisfactory outcome. Several people have made the purchase and found out the hard way they needed new wheels.
Good luck!
Yeah im thinking about it, would you just get them at a pick n pull or junkyard?You can save a bunch of bucks by using’73 - ‘76 a body upper control arms, spindles, lower ball joints , rotors, calibers .
