/6 with 904 vs 318 with 904
Johnny71dusty
Maryland
are the transmission lines the same ? Ones for v8 are 30-45$ . Once for slant are 150-200$ ? Aren't the trans the same other than the bell ?
Hate to waste cash if not needed
They are bent different past the starter and the block. With a cheap bender you can make them work either way. The ends are the same and they travel the same distance and go to the same spot on the transmission and radiator.
Get yourself one of these (or some variation of it)... You won't believe how many times you'll use it.
