If your using something like a roll master billet gear and chain setup you would think something like that would be dead on dot to dot.
You never know till you measure it.
Some of us anyway.That's true, then you wont truly have piece of mind
An issue I am thinking of is these newer outsourced parts, what if the "dots " are marked wrong. i have always ran mine dot to dot, but have degreed cams in tech school I have done it before but it was many years ago, and I probably didn't truly understand what i was doing. The teacher was like "good work" I said " i still dont know what i did...![]()
I would think its a crucial step in optimal tuning getting that mechanical valve timing dead on.
True, but how close is close enough?
I think people fuss too much about 'exact' cam position. Dot to dot, 4* adv or 4* retarded etc...
Unless you are building an exact duplicate that was dyno tested & the cam position varied to get best HP, it is just a guessing game.
David Vizard makes a very good point about cam position: the closer the cam specs are to being perfect for that parts combination, the more HP will be lost if the cam position is not optimised. The opposite applies.....
For the average Joe [ or John or Jill.. ], I would install it dot to dot. After the engine has been run, you can change the cam position to see what, if any, difference it makes.
I don't and I can give you great example of why. I built a 454 Chevy for a guy years ago. I used a Comp billet set on a Comp solid flat tappet. I put the wheel on it. Came up 12 degrees retarded. TWELVE. The number after eleven and before thirteen. TWELVE. That's been about 25 years ago and I still have a hard time believing it. But it was right. I duplicated it five or six times. It took an offset bushing in the cam sprocket along with the nine keyway crank gear to get it right, but I did and it ran like the dung who flung. That right there taught me to check them all and if somebody doesn't want to pay me to do it, I'll load their junk on their truck.
off set keys on a SBMSo, do you "ajust the cam gear" with offset keyways and eccentric bushings?
indeed. There is a thread in the BB section where things were lined up, cam was 8* retarded. It's in correctly now and the report is the car runs a BUNCH better. There are times this pops up when installing.
Just spend the time to degree the cam so you know it's installed where it should be.
so what type of performance issues would arise going dot to dot vs degreeing? has anyone experienced a "revelation" when degreeing as in the car **** and git way better than dot to dot?
Eccentric bushing for BB Mopar. Of course, they make multi keyway sprockets for most timing gear sets, nowadays, if you need that option.So, do you "ajust the cam gear" with offset keyways and eccentric bushings?
How do you know its " Straight up?"Maybe I have just been lucky. I have built quite a few engines in my day, and I have never degreed a cam. I have never had a problem, and every engine ran great. My current 340 is probably at least 75HP over stock, and it runs really well with a 'straight up' cam in
