A 833 Overdrive Shift lever
57 Fargo
Active Member
Grimshaw
Hi all, I’m wondering if anyone has a reverse shift lever off an overdrive 833, I’m looking for the dimensions of it.
Thanks in advance.
I have one. Actually two. Do you need it for a truck or a car?
The transmission/shifter is out of a truck but it’s going in an early Barracuda. For some reason I’ve misplaced the reverse shift lever that’s on the transmission, if you wouldn’t mind taking some measurements I can whip one up.
