Chris1974
I agree with Dana and I have a new pioneer that has memory and will drain my battery so I have it on a trickle charger 24/7 I dont unplug my fridge when I go on vacation..
Now what if your kill switch contacts start getting corroded or loose and you get a weak connection and while cranking, you build up excessive heat and it starts a fire.Lot's of controversy on whether it's a good idea or not to have a kill switch or disconnect switch etc. We have all heard the crazy stories where we ask "how could that happen ". So for me I believe the cost and inconvenience of turning on / off the switch is small compared to losing my cherished old mopar. Just like I have it insured in case something stupid happens. Better to error on the side of caution. You may disagree
But at least you are present to deal with the situation not on say a weekend get away. Yes there is always possibility of something happening but again just maybe cutting down on possible scenarios might help. As far as every time you switch it on and off it wears down kinda like your brakes wear a little every time you use em but I'm glad they're there. Just saying.Now what if your kill switch contacts start getting corroded or loose and you get a weak connection and while cranking, you build up excessive heat and it starts a fire.
Every time you flip a switch or disconnect a disconnect is one time less it can be connected or disconnected in the future.
Lot's of controversy on whether it's a good idea or not to have a kill switch or disconnect switch etc. We have all heard the crazy stories where we ask "how could that happen ". So for me I believe the cost and inconvenience of turning on / off the switch is small compared to losing my cherished old mopar. Just like I have it insured in case something stupid happens. Better to error on the side of caution. You may disagree.
I Have two batteries in my trunk both are disconnected after useThis might sound weird and I might get laught on, but I'm just wondering if I'm the only one with this "fear".
I always disconnect the battery (I have installed a battery dosconnect switch) when I park my '74, even on meets. I'm worried about a fire caused by the battery. I mean, if I turn off the car and the battery is connected, there's still some load on the wires, right? I just think due to the age of the wiring, isn't it possible to cause a fire when the battery isn't disconnected?
I have to say, I've had two incidents with the wiring that almost ended in a fire (broken original amp. meter that ended pretty bad and a blown fuse)
I agree with what you’re saying however none of the items that you named are operational unless they’re activated by a human. So another words they are off until you turn them on even though they’re on a live circuit.I don't think that is 100% true. If what you are saying then how would one turn on the four way flashers, lock the car on the side of the road and proceed to get help if say you ran out of gas ?? The interior light, horn, cigarette lighter, headlight and possibly a few other accessories will operate without the key in the ignition. So to answer the OP's question, it's not a bad practice to have a quick disconnect switch and to use it. Just my thoughts.
That must have been a really bad battery.My 69 Charger’s clock would kill my battery within a week if I left the battery connected
Nope, brand new, happened on three new batteries.That must have been a really bad battery.
I don't get a spark and it goes straight to the starter with a smaller wire to the relay.The cable on the battery doesn't go to the starter. It goes to the starter relay. There is another smaller wire there that makes all sorts of chit hot. Maybe best to just see for yourself. Open the door so dome lamp is on or better yet pull the headlights on. Remove and replace positive cable at battery. See spark jump. Next try same with neg' battery cable. No spark.
When I'm working on the car I disconnect both.Maybe so, but @RedFish is right. When only disconnecting one cable, it's best practice to disconnect the negative. At my job, we run car fires ALL THE TIME at wrecking yards where "other" fire departments yanked the positive and left it dangling. After some jostling on the tow truck and shifting from being set down in the yard, the positive makes contact and shorts. Boom. The car is on fire.
I do too, even in my daily drivers.To the people giving me **** I hope you carry a fire extinguisher because I do.
So with the car left unattended, you only disconnect the positive? Why not take the extra step and disconnect both?When I'm working on the car I disconnect both.
I unplug the toaster every morning when I leave. I just don’t trust those things!Do you unplug all of your lamps and blenders etc from your home when you leave?
A switched cir that is attached to the battery has 0 amps flowing while the switch is off.
It's the same as the battery disconnect switch
I know a guy that goes outside and throws the MAIN breaker at the meter box when he leaves his house. He had a house fire years ago that was caused by electrical. He says he sees the difference on his power bill too. lolI unplug the toaster every morning when I leave. I just don’t trust those things!
