1'' bypass hose issue
rigger3006
north america
i picked up a weiand xcelerator sb intake, it has a 3/4'' bypass hose fitting.my water pump and intake have 1'', is there an adapter fitting for this, if i can even get the old fitting out of the weiand
No need to change the fitting, I had the same issue with mine. I just cut a piece of 3/4 heater hose ( about 3/4 long ) and slid it on the 3/4 fitting. Your 1" bypass hose will slide over the 3/4 heater hose. You can use a little bit of silicone between the two if you want. I ran mine like that for years until I installed my LD340 this spring. Bobby
If you want to remove, soak in PB Blaster and let sit. Be careful if you use heat.
Alternative way is to cut "cross hairs" in the end with a hacksaw blade. You've cut it into 1/4's, now you can "fold" each 1/4 in. Hope that makes sense.
so just cut and fold down to 3/4''?
hmmm......good idea,thanks
I think what @4spdragtop was referring to is to cut the nipple into 1/4's and bend them inward until they break off. With the slits cut, the rest of the nipple should tear off inside the threaded portion......Am I reading you correct Steve?
Sorry, yes CFD/Troy explained it better than me, cut/slice down to where nipple enters the intake and fold/bend the 4 corners in.
