Port size rpm performer manifold question
Duster Duke Boy
usa
I need to know what size this port is on an Edelbrock performer rpm for a small block 360 see pic?
it looks like 1/2 npt but not sure.
it goes to the heater core and I need to swap it for a 1/2 in nipple, currently has a 5/8
Thanks
I don't own a Ed rpm, but I betcha it's 3/8 NPT. On my Speedmaster intake, the hole in that location is 3/8 NPT. Hole on PS next to thermostat housing is 1/4 NPT (on SM intake )which is what I used for my 1/2 heater hose. Hole next to it is 1/8 NPT, which I used for temp gauge. See pic :
Thanks maybe I should swap heater to the ps hole
So the one on drivers side is 5/8 npt and one on pass side is 1/2 npt. just in case anyone needs that info
Listen to @TT5.9mag . I just measured the RPM manifold that's on my shelf. Trust me. Pipe is measured by ID of the pipe itself, not by the thread dimensions. NPT is measured completely different than standard thread pitch. 5/8" NPT is HUGE.
I’m just trying to learn not about not trusting, trying to understand. if I measure hole at 1/2 in how do I know what size npt it is?
Npt will be confusing at first, but once you work with it for a while you will recognize the sizes and become familiar with it. The taper gives it away. NPT fittings are common on anything that is supposed to retain a fluid. And use a thread sealer on them. Mostly for lubricating the threads but also to seal up. I prefer the loctite paste.
Thanks
Hey no biggie. We've all gotta start somewhere. Good on you for trying to figure it. Besides the photo above, check out a standard drill chart. a 1/2-14 NPT tap uses a 23/32" drill bit (nearly 3/4") whereas a 3/8-18 NPT uses a 37/64" (about 9/16"). I reference the one on my wall all the time.
I never was good at fittings but trying to get better thanks
