WAYNE0
So i finally got the supercharger kit & it came with a blow-thru carb. Once i collect all the other parts i need like fuel pump, regulator & timing retard knob i will take some pics of the assembly & post them. The kit is the same one that Summit racing sells. The carb is a quick fuel 750 cfm blow-thru. They also recommend a 1-2 colder spark plug. Ill have to do some research on them. Right now i have champions 12ryc plugs. The kit seams kindve easy. The only thing im not to sure about is the oil return line. They want you to punch a hole in the oil pan with a punch & then screw the fitting for the line into that. If wouldnt be such a big pain i would drop the pan & weld a bung on it. I also have to get a carb hat, it doent come with kit. Ill keep you all posted
