360 vs 383
383 or 360 ?
  • overall, 383 all things considered
    Votes: 34 60.7%
  • overall, 360 all things considered
    Votes: 22 39.3%
  • Total voters
    56
It's kind of interesting (to me) to compare the rated rpm's for these motors.
__________HP________TQ
'71 340 - 235@5000 - 310@3200
'73 340 - 240@4800 - 295@3600
'74 260 - 245@4800 - 320@3600
Doesn't make sense to me why the '73 340 with lower compression and a log manifold on the right was rated 5 hp higher than the '71 340. But the rated RPM is different, too. Maybe the first generation TQ hurt the hp on the '71? I mean, all three have the same cam so it would seem like peaks would be pretty close, right?
Agree. Theoretically, a 74 360 has 10 more hp and tq than a high compression 340
Nope, ain't buying that for a minute.
Yes, they are and different ways of calculating the number also. Those are not what class racers are running for hp, it is a factor to pair up racers. the real hp is much higher. Not a theoretical guy. No youtube, no calculators, no racing (my friends do that). Just built engines in the old days. Used to buy cars with 360's pull the heads, 727 trans, and 8 3/4 pig and send them to the scrap yard. A lot of back in the day has not changed. There are those who can, and those who can't. Who needs 750 on the street. If you seriously want that I can give you a contact for a "440" that will do more than that on pump gas. I am happy with around 300 real hp. Have fun playing with your calculator.
thats just not true
its based on mph run and weight of the car for stock engines and its up to date
there is a reason 340 and 360 abodys hold 99.9% of the records
show me a stock 383 b body winning anything they dont
show me a 383 a body winning anything they dont
340 and later 360s hold a **** load records
It amazes me on an A-body mopar site folks dont know whats the best setup for class races
OK but you used NHRA specs to make a point and used them incorrectly at that.
Calculators are tools. Mock them all you want but I’ll base whatever I’m doing on data and fact.
None of that makes sense or has any relevance to the discussion. It also sounds as if you’ve been living under a rock for the last 50 years.
Which is true for all walks of life. Your point being?
No one needs it but it’s fun to have it. I don’t think anyone is talking about building a 700 hp street 383 engine either. I used the example to illustrate that to run a number within a particular racing class, you’d need *** hp to do it. Not sure how you twisted that around?
Why even bother with a V8 then? I personally wouldn’t be happy with such mediocre output. I wouldn’t advertise it either.
You make it seem like using tools to gain information is a bad thing. Don’t mock what you don’t understand. understanding comes from knowledge and knowledge comes from information. Right?
Honestly though, your arguments are mostly emotional ones. Engine building is a technological pursuit based in fact and hard numbers which is the opposite of emotion.
Have fun making less power than the engines originally came with.
1. Can I cheat and say magnum 360? In an a body specifically I dont see the 383 being worth the difference in cost and size.
2. Same. 360 magnum.
3. Same 360 magnum. Every 383 block will need machine work. That's money I won't spend on a 5.9 block that will let me buy better heads.
4.383. Bigger is better and better flowing heads are available
My rule of thumb is bang for buck is always magnum 5.9 but if I were a legit racer or I need torque for a truck bigger is better.
This is probably already been brought out , and I am sorry for resurfacing if it has, but. If we're going to compare magnum to 383, then why not compare Magnum to Magnum 5.9l-360 to 6.2l-383. I kinda feel disadvantage otherwise.
I have to ask.... say you scrapped 360's then and do it now ... but your happy with 300 hp.... ??
No, years go I decided I needed an inside job, when a Chevy starter literally froze to my hand. I have not scrapped many cars since the 80's when I got my Mech Eng job. I have no problem with 360's, I just have 340's and 273's a couple 383's, and a 440. I do have plenty of 360 heads still. My choice is hard to understand if all you want is hp. Where do you stop? Unlike you I do not drag race, I drive a lot on the street and have High Performance engines with multiple hundreds of thousands of miles on them. Fast, bullet proof, and longevity is my goal.
I had a '68 Fury III Police Package (build sheet verified). It came with factory disc brakes, dual exhaust, 383 commando, and dual mirrors. 727 of course. In low mileage-stock form it ran lower 15's with even the factory carburetor still on it. About 4400 lbs at the start line (no spare or jack, me in it). I thought that was respectful considering where the car dated and era.
We added 3.55's, a weiand intake and 750 holley and dropped down to 14.7's. About a half second drop. Not at all fast, but when all considered, respectful.
Brought old memories for me there. I had a '67 that 383 commando w/2bbl. I ran 14.90s with it but it had nature's weight reduction also. The car originally was a Minnesota car. Open the trunk lid and see both back tires,lol
I had a 71 340 Cuda and my best friend had a 383 Super Bee, similar hop ups. We raced many times and although my car with a four speed and better handling was funner to drive. His Bee would consistently be a car length or two faster than mine. I would say they were close enough in power that I would take the 340.
Sounds like you had a real world experience.
If you'd of had a 360, that'd have made up the difference!
:poke:
:lol:
Im not sure I understand. There is no modern 6.2 version of the 383. The magnum 383 still was discontinued around 1971.
thats just not true
Class racing is NOT what I am talking about. My friend raced Super Stock, I know most of what it takes. I am talking about street or street performance! Someone said 383's are dogs. That is not true, they are both in the same ballpark maybe a couple factored hp. Big deal. I prefer a 383 over a 360 and none of you guy's opinions will change that. Always have, always will.
I don't have a 383 that has no power and won't pull past 4,000 rpm. I have the information and experience, I just don't need what you are trying to give me. Do you build engines or have built engines for others?
I got it. The '71 340 was the last year for the 2.02 heads, right? I bet when the 340 and 360 moved to a 1.88 head they picked up power. Has to be the difference.
:rofl:
The 383 b body stock 4sp cars ran 15.0 low 90s 91 92 mph stock a couple 14.7s@94
imo thats slow as chit for a big block 4spd the 383 was over rated from the factory the 340 under rated
Anything can be made to go with money even 301 turbo ta dog even the 305 chevy dog
Now those stroked 383s impressive numbers
mopar should have left the over rated engines to cheby
Additionally, I want it all. I want mpg, speed, and plenty of power. I won't run headers, aluminum heads, or a stroker. I'm tired of chasing the supposed latest "best" thing. I have no problem making power with factory cast iron heads, forged cranks, on any block I choose. Think of a stock class race engine with a street cam, usually a custom Racer Brown solid flat tappet. I run full exhaust, since I sometimes drive at 70-80 mph for 12-15 hours a day. Not fun in a race car. That is my thinking.
I worked for Chrysler through the mid 70's and drove HP 360 Dusters. Sorry to report they were not that fast. I even looked into buying one but after the test drive, I passed because my 64 Barracuda with a 273 was quicker.
