Low voltage at gauge, no charge?
70SwingerGuy
Long Haired Freaky Person
Republic of Western Canada
Fired up the (until now running beautiful)70 swinger today, 340, MSD ignition, and right away noticed that my Autometer voltmeter wasnt showing around 14 anymore, but a hair over 12 without fluctuation. Took it for a quick drive around the block and no change, half a block away from home, I hear a slight FZZZZ behind my dash with what I think was a burning smell/possible slight smoke, got it into the garage and shut down with a slight knocking/detonation, which it never does. Subsequent run/stops have resulted in a slight ticking/knocking(about a dozen then stops) in the motor while being shut down, which again, it never has done. I havent pulled the dash bezel yet, but I was following the troubleshooting steps found in this post:
testing voltage regulator and this is what I found:
- unclipped the green field wire at the alt and grounded it, with the key in "run" without starting, voltage at the blue field wire was just 11.69v, battery was at 12.52 disconnecting/connecting the clip on the green terminal resulted in sparks as should be. Started the motor with my voltmeter on the battery and the voltage dropped to 12.4 and didnt increase.
- started the engine with the clip lead still installed, voltage at battery was 12.42, at the alternator bat post, it fluctuated between 27-28v
-disconnected the VR connector and the blue lead showed 11.69v and the battery was 12.59
-tested the green field wire for continuity with success.
- internal Autometer voltmeter stays a hair over 12v and doesnt move
The voltage regulator that I have looks to be the cheap silver one with made in China on the back; Ive watched a vid or two that say NOT to put these cheapos on, that they can be dangerous, and to only use the genuine Mopar regulators.
Im betting that the VR crapped out, dont know about behind the dash or the knocking yet
Any opinions/ideas/suggestions?
Edit: Its also highly recommended to ground the VR, is it ok just to run a ground wire from one of the mounting bolts on the VR to a ground source, rather than just rely on the mounting bolts for the ground?
I would "guess" perhaps the low voltage due to the no charge condition might be making the ignition do some funky things causing the knock/detonation.
You mentioned 27-28V?? That will fry stuff for sure. I run a seperate ground from underhood voltage reg direct to batt -ve.
Dbl chk/clean connections at bulkhead connector. You should crawl under dash to inspect. Especially after noise/smell.
your best friend for grounds
OK let's start over. What this sounds like is that you HAVE A BREAK in the output or "charge" wire from the alternator to the battery
So the basics of what you want to do is this:
1...Determine if the output/ charge path from the alternator to the battery is OK
2...Determine if the VR is OK and wired and working OK
3...Determine if the alternator is working, wired OK, and operating OK
So to test the alternator, sounds like you successfully checked for power at the blue field (which is quite simply same as switched 12V or "ignition run"
Now what you want to do is take a jumper and remove the green field wire, and ground that alternator field terminal. With the key "in run" that will cause full field current and if the alternator is healty, will cause full charge output.
So double check---ground the field as I just mentioned, and re check battery voltage and re check the output post at the alternator. If the battery is still below 14V with the engine "fast idle," but if the alternator is still way high, you have a break in the charge wire circuit
Do you have stock wiring, do you still have the ammeter? If so that entire circuit is suspect. The bulkhead connector terminals for the black output wire and for the red ammeter wire, the ammeter itself, in rare cases, the welded splice in the ammeter circuit up near the cluster., and the eyelet connectors at the alternator and at the ammeter., and whatever wiring gets the fuse link to the battery.
IF THE accessories, lights, etc, still seem to work OK, then some of that is eliminated. This leaves only the welded splice and bulkhead connector terminals and the alternator black wire and end eyelet.
HAVE YOU smelled anything, smoke, heat, etc? That is a clue
Read this
and this diagram from the same page is the simplified ammeter path
In the above diagram, note that as you follow the RED ammeter wire from the battery, fuse link, through the bulkhead connector, ammeter, out on the BLACK ammeter wire and to the WELDED SPLICE, that path must be good for stuff like the accessories and headlights, brake lights, etc to work. But AFTER that welded splice, the black continues on, on out through the bulkhead connector on BLACK, and to the alternator output. That last section is likely the problem.
If you do not have a factory service manual, run over to MyMopar.com and download the closest one you can find. You may have to settle for Plymouth vs Dodge, etc, and also while there, go to the wiring section, and download the aftermarket wiring diagrams. Those are not as detailed or complete, but often easier to follow
Aside from the MSD electronic ignition, it appears to be relatively stock, with the addition of some aftermarket Autometer gauges.
The ammeter is still there and connected, I just put in a replacement fuel gauge with the IVR upgrade, and a new tach so I know this to be true.
Preliminary check of the accessories show that everything(with the exception of the pass front signal light group, which wasnt working before) is working EXCEPT for the headlights, but the dash lights, aftermarket gauge lights, and taillights come on when the headlight switch is on, headlights were working fine before.
I heard a slight "fzzzz" sound behind the dash cluster, and me and the wife both thought we smelled a bit of smoke, and I wasnt sure but I thought I may have seen some in the air.
I think it may be notable to mention that the voltage was low/not moving on my gauge as soon as I started the car, it wasnt until after running it for a few minutes that the sound/smell occurred.
That MAD link has a WEALTH of great information, thank you for this!
Darn, man. If the headlights don't work this sounds like probably the welded splice has broken. You will have to pull the cluster to check. the welded splice is a few inches away from the ammeter black wire termination, wrapped up in the dash harness. Once you get the cluster out, you can unwrap the harness working back from the ammeter. Follow that big black back
First one of these I ever found was in the early 70's in a friend's 68 RR. We had the cluster and part of the wiring torn out of the dash in his apartment parking lot. He was beginning to think I was an idiot AND I WAS TOO!!!! LOL
So what could cause that splice to actually break and let go?? The night before I had to "dimple" one the pipes of my new headers, so possibly the shock/vibration of hitting it with the hammer may have caused it to break?
I've had the cluster out a few times recently, so Ive gotten pretty good at it at least :)
What would you recommend for a proper fix of that weld? Also, would bypassing the ammeter by joining the red and black wires be recommended at this stage? Im not sure I understand where the danger lies in the ammeter, I understand that the circuit is a long one from battery to gauge to alternator, but is it the gauge itself that may fail and start a fire, or somewhere else in the wiring along that path?
Thank you again for your help and information, its appreciated and Im learning alot :)
Luckily Im in my garage! I also had a 68 RR many a moon ago, my first mopar, I miss that car.
The danger of the ammeter circuit is that the entire end to end circuit/ harness/ connections AND THE meter is marginal. They mostly worked OK with smaller alternators for the expected life of these cars.
The wire size was marginal, the bulkhead connector terminals were never designed for that kind of amperage, and the ammeter itself can loosen up and cause problems.
But now that they are antiques, now that people install big alternators, big stereos, etc etc, and now that the connector terminals have had half a century to oxidize, things get worse.
You need to repair or bypass the bulkhead connector terminals, not just the ammeter terminals.
@67Dart273 Ive been reading the MAD links that you provided, and they are providing a lot of good information. I have a question about the splice of the two 10g(red/black) wires which join to the 16g fusible link, in the pic they provide, they dont show how they spliced and joined all three pieces securely, have you done this before, can you recommend a way to do this?
Actually I should have qualified. Most of us here do not do that bypass as shown. Rather, I usually mention it is a good overview to the what happens and why
Simply, bypass the ammeter by fastening the ammeter wires together or fix it by soldering the studs to the shunt and make sure the ammeter wires are "good," and fix the bulkhead connector terminals, either by replacement, or by running wires straight through the connector body.
Then after doing the above, run a BIG fused or fuse link protected bypass wire direct from the alternator output to the battery
@67Dart273 Thanks for the clarification on that. My plan is to upgrade the wiring as per the MAD document, the guy makes a lot of sense in it. I dont think my alternator output wire is even a 10g, maybe a 12, so Im going to run an entire new length of 10g from the alternator output direct to the battery with no splices at all, utilizing a 14g fusible link at the starter relay. As for the under dash stuff, Im going to join the red and black at the amp gauge, and utilize a new piece of 10g red, one piece direct to the starter relay as well, so the only wire the I will have to splice is the black through the firewall and connecting to the red before the relay, with a 16g fusible link. Depending on how that black is run under the dash and spliced into that welded splice, I just may replace it with a one piece running straight from the welded splice out to be joined with the red before the starter relay.
Unless I get lazy once I get the dash bezel out, then my plan may change.. :lol:
Thanks again for all your help, it was greatly appreciated, and most helpful!
@67Dart273 So heres an update Im hoping you can help me with, you seem very knowledgeable in this area.
I have done the entire MAD wiring upgrade, just as they instructed, both the direct to battery from alternator fix, and the amp gauge bypass. The only ways I strayed from their instructions was I avoided splicing to lengthen wires by replacing the old wires(black and red main wires) with new 10g single piece wiring, much cleaner and efficient of course, and secondly by avoiding another "welded splice" by utilizing a Wago wire connector rated for 10-20 gauge wire to connect all those wires. Google these if you havent heard of them, they are amazing, Ive used the 12-24g version many times in household wiring with great success.
So everything seems to be working fine, car starts and runs fine, my volt gauge says Im charging again, and everything works EXCEPT for the headlights. At the fuse block, the #1 terminal has no power to it at all with key on, and Im sure it is the cause of my problem; when I was putting it all back together, I mistakenly put the red with tracer wire from the "splice" to the #1 and I had headlights, but other problems such as dash lights staying on, no buzzer when the key is in the ignition, and the dome light not coming on at all. I figured out my mistake and put it on terminal #2 as shown in the pic and everything now works but the headlights.
So obviously my question is, did I disconnect something from the #1 that I did not reconnect? I cant see any extra wire laying around, but in all the process of doing this, something may have gotten taken off and not accounted for. Or perhaps its something else that I havent considered? Did I fry the headlight switch perhaps??
Also, these is power at the B1 and B2 connections on the headlight connector.
I have also replaced the cheap chinese VR with a factory Mopar unit.
I know this has to be something fairly straight forward that Im missing, but electrical is not my specialty.
Im soooo close to having this fixed, any help and suggestions are greatly appreciated.
The headlight switch headlights only power (you probably realize) originally got UNFUSED power from the welded splice. This was likely done to INSURE that you would never lose headlights unless the main fuse link blew. It is important to carefully pick your headlight power source so you aren't suddenly "in the dark."
But if both B1 and B2 are getting power WITH THE SWITCH ON (under load) then I would say you are in the wrong area.
Next thing to do is see if the HL switch is sending power down to the dimmer
B1 is headlights only, B2 is tail/ park and instrument lamps
When I did this upgrade, I left the connections under the dash the same as when I started, with the exception of the ammeter bypass of course, so headlight power source should be the same as it was.
I never checked for power with the switch on, only key on, the switch is still in the cluster, Ill take it out and hook it up to check.
Could a bad dimmer switch be the culprit? I think I saw a post somewhere on this site where a member stated that a bad switch can cause no lights at all. I will check for power down at the dimmer when I hook up the switch
thank you again for all your help and direction :)
The reason I always (if possible) suggest checking power with the key on, is in case of a bad switch or in the case of a headlight switch, the built in breaker
It is very possible you could check power at the B1 terminal and it's OK (you think) but then with the switch on, no lights!! Could be the switch is bad, or could be a bad connection in the wiring BEFORE the switch is droppin power off when you try to load it.
@67Dart273 FIXED!! Turns out the headlight problem was a bend spade terminal on the switch, I must have put the connector on cockeyed the first time it went back together and it bent the B1 terminal down, once straightened, everything works as it should :)
Thanks for all your help, it was much appreciated, beers would be in order if you were closer, cheers!!
VERY good. Breaker, yes. In stock form the HL power is fed off the black ammeter wire, ONLY fuse in the fuse link. The HL switch has a breaker in/ on the switch. (I don't know about the early girls they may be external) Normall inside the switch.
How well I know about the breaker. When I upgraded the headlights on Gladys, my 75 Ford truck to H4 Halogens, I didn't put the upgraded relay harness in. Coming home from work after closing, the headlights flashed morse code until I dimmed them. I got the upgraded harness with relays and it's never done it again and the headlight switch is cool as a cucumber. lol
