[WANTED] Inner fender splash shields
nodemon
St.Louis
Looking for a set of inner fender splash shields for a 72 Demon.
I know they're repopped, but hoping to save a few bucks buying used..
Thanks,
John
Unless this is a perfect factory restoration: Look for splash shields from a 1973 and later Dart. They are made of heavy plastic. They never rust, they fit perfectly and they weigh a pound less. They are often cheaper than a used rusty set of metal ones. I have them on 2 of my 1970 Darts.
I have these plastic ones from a 74 Duster. They should bolt right up but I think the fender contour may be different for Demons/Darts, but being made of plastic, I'm not sure. They aren't perfect, but pretty nice for $25 for the pair + the shipping
No!!! the inner fender panels are different between plymouth and dodge Abodies because the shape of the wheel opening is different. Dart, Demon and Dart Sport are the same, Duster and Scamp are the same
@str12-340 - do the differences between Dodge and Plymouth you refer to apply to the metal ones the OP was looking for or to both the metal and later plastic ones ?
Metal and plastic - if you look at the pictures in post 4 above, the Plymouth ones have a "pocket" molded in for the bolt that is Not on the edge of the piece. Dodge fender openings sweep back, while the Plymouth ones are straight up and down. The pocket moves the outside edge to that straight up and down position. Used on a Dart it would be out in the air instead of tucked behind the wheel opening lip. Here is a Dodge picture. If someone could post a Plymouth picture the mismatch would be obvious.
I have a pair from a 71 demon that are metal that have no rust and I'll let you get them for a good price I can send a picture tomorrow
Oem ....no rust, no rot....not even pitting...$120 plus shipping
Also have 72 demon scoop with no Notch for the ridge made specially for 72 demon almost NOS condition I also have another one and 72 demon bucket seats if needed they have the tracks on them
