[WANTED] Looking for one of these specific small block water pump pulleys
MobileCustoms
You can twist perceptions, reality won't budge
Rush City, MN
Does anybody have one of these for sale, just like the photo and dimensions?
OD: 5 3/4" and 2 3/4" tall
Thanks!
I haven't had time to look for the pulley. Unexpected company. Sorry as soon as they leave, I will look for you. I know it can be frustrating waiting to hear about a part you need and I do apologize. MIKE
I have pulleys from my 66 Barracuda 273. I'll find it and measure it see if it fits your need.
No worries, family comes first!
Dug up the pully I have does not match the measurements you posted. Its a 3.5 od not 5.75. I'll look around I have a friend with lots of old pulleys.
Well, I made a mistake. The pulley that I'm looking for is the same as in the original photo that posted, but it needs to be 3" tall rather than the 2 3/4" that's shown in the photo. And it wouldn't hurt if the diameter is a little less than the 5 3/4" either, but the 5 3/4" would be fine as well.
Thanks, Here's an updated photo with corrected dimensions:
Sorry it took me so long to get back to you. I just had lower back surgery, and I can't get around well yet. As soon as I can get back into my shop, I'll dig out the pully I have. I told you it measured 3.5 od. I'll remeasure it to see if I made a mistake maybe its 3.25. If not, would it help if you had both pulleys top and bottom? I have 2 more weeks of recovery before I can get out and do things. Maybe with both pulleys you can move the power steering pump and alternator out a little with washers. Mike
It might help, depend on all the measurements, once you have a chance to dig them out. I might just use a 1/4" crank pulley spacer to make the ones I have now all line up as an alternative.
Thanks and good luck with recovery!
