Spare tire pic ?
I'm having the same questions with my spare. I bought a 14 x 5.5" plain steel wheel and put a BFG Radial T/A 215/70-14 on it to match my tires. It sits in the tire well a good 3" above the rest of the trunk floor. I'm not sure if I need to change the tire size or get a different wheel?
A 215 tire is probably about 8-1/2" wide at the tread, so there's no way you'll get it to fit down into a 6" deep spare tire well. That's the problem I've run into - the well is too shallow.
The original spare in my 1970 Dart is a D78-14.
Basically a 205/70-14.
The spare sticking up a little in the well is really no big deal,even the stock spare sticks out a little. The board and matt cover it up just fine.
I believe 69 and earlier cars actually have a smaller tire well.
340 cars would get a E70-14 which would be about the size of a 205-70-14 which doesnt fit in the well either.
That sounds about right. A 205 tire should be approximately 8" tall and would stick up a couple of inches above the 6" well. I'll keep looking.
Thanks for the info.
Hey Adam.
The short stud is for sure 6". Went out and measured it.
In the pic it looks as though the long one is about 1" longer.
So I would say 7".
I would go take the spare apart,but I'm beat. Long day.
Would you know who reproduces the ring and wing nut above the fiber board and what it's called?
If you're looking for them, post a wanted ad in the classifieds. Just be careful to buy from a member who has been around for a while to avoid scams. There's not many scamers around but now again one sneaks through.
I bought some spare tire hardware years ago off FABO.
This is a pretty old thread, and looking at my pics, the wing nut, which you are referring to, should be smaller than the one I have. I'm going to be on the hunt for the correct one.
Having said that, put a parts wanted thread here, or search the internet.
Anybody have a pic of the correct way/factory way to secure the spare tire with the jack hook and jack base in a 1970 Dart ?
Would really apreciate it.
Thanks
JD
I have a picture from a 1969 Dart, this is from my owners manual I do not believe it has changed
I have mine but its badly warped I wonder if I can make it flat again by wetting it etc.
That's wild because I envisioned the same thing. I don't have mine and was originally looking for info on if there was a board of some kind from the factory. I was thinking if I could find a beat up one, could you wet it and lay a piece of plywood on it while it dried?? If I had one, I'd just buy a half sheet of fiberboard, trace it and cut it out.
