Photos of V8 power steering hose setup?
Woodsman341
Columbia, SC
Hi guys and gals,
I'm trying to replace some bad power steering hoses on my wife's "new" 1975 Dart Sport. It was originally a slant 6 but was swapped to a 340 with a Saginaw pump. No matter which site I look at, I'm seeing hoses with a fairly straight section on the pump end, and hers is more serpentine. Pictures attached.
Can anyone show pics of their setup with a Saginaw pump? Maybe these newer hoses will work, but I can't visualize how that straight section would fit.
I've tried looking up earlier 340 hoses, slant 6 hoses, and nothing matches visually. There are places that sell Federal pump hoses that look similar, but the federal has an o-ring connection whereas the Saginaw has an inverted flare.
Editing to attach photos of the pump, which I was told is an early Saginaw.
This one for a '74 Plymouth / Dart slant 6 on ebay looks very close although the bottom loop on yours was manipulated somewhat.
As I recall, your year with the spool motor mounts has a lot of room. Many different ones should work. Just get one and try it.
Thanks, Mike, I think I'll have to. Yeah, there
View attachment 1716307690View attachment 1716307691
I'll check. The funny thing is I thought, "Hey that one picture looks JUST like the one I have!" It took a second to realize that yeah, that's my house in a spare door. :D
lol, I just wanted to have a better side by side.
Seems close after a 3rd and 4th look maybe not unless you could safely reshape both ends
Glad to help, I always get TRW and Federal mixed up lol. I actually had to zip tie it in place under the tray. The metal part in the middle of the hose was rattling against inner fender. Thankfully there were a couple factory holes there to use lol.
Thanks! Yours is a Federal (which you probably mentioned), but it's good to see what the routing looks like.
AND - thanks for the picture under the battery tray, that really does help!
