[WANTED] 3 Groove crank pulley for cast iron water pump small block
BergmanAutoCraft
FABO Vendor
FABO Vendor
Hampstead, NC
As the title says. The cast iron water pump small blocks (up to 69) are not the same as later 70 and LA small blocks. I'm looking for a 3 groove crank pulley for an AC small block.
PM me with what you have.
I have this one.
Came off a 68 or 69 318 with cast iron water pump.
The engine was not original to the 67 dart but the car had AC and Power Steering. The idler was present on the engine
It most likely has sat in TX or CO (high desert) since 1976
The pulleys measure:
I took tape and ran it around the pulley outer dia then made a mark, measured the length (circumference) and converted that to dia
Inner 6.2" dia
Middle 6.6" dia
Outer 7.87" dia
Depth, face down on a table, is 3-13/16 outside to outside.
The rubber isolator pretty but it is soft.
It is how I pulled it off, I have not done anything to it, not even washed it.
$50.00 plus shipping (obo)
I have a set on e-bay alt. & p/s the a/c pulley is separate check it out item# is 387314979878 let me know if that is what you can use
Joe
