Plumbing a '69 style filler neck vent
SomeRandomDude
Active Member
North Texas
I'm replacing the fuel lines on my 73 dart - but the vent line that used to run to the charcoal canister is now going to be a vapor return line - so I'll need a different vent. I've seen suggested here many times that users could add a '69 style vent to the filler tube, plumb a loop up high from there, and back down through to the exterior. I'll be pulling the neck to do this but I have the following questions: Is it necessary to have someone weld a fitting to the neck or can I simply drill a hole and add a fitting thats threaded on the inside and secured w/ a nut? If I go that route I'm guessing just a thicker rubber washer/gasket will provide a good enough seal even with the fitting being added to a round pipe? And lastly - would there be any benefit to adding a charcoal canister in the truck to plumb the vent through prior to routing it to the exterior? I'm thinking it would help w/ fumes in the garage, which haven't been an issue - but not sure if this new system would cause more fumes. I also am trying to keep the engine bay as clean as possible and would not like to add one there. From what I read it seems like the canisters needed a vacuum to release vapors back to the tank as originally designed but maybe I'm reading that wrong. Any help would be appreciated.
Very simple. Look it up in the 69 or earlier service manual
Post no5 in this thread
