HELP WITH A 2007 DODGE RAM 1500 CONDENSER RAD FAN NEEDED
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I have an 07 ram with a 5.7 engine. Whenever I turn the selector to "defrost/defog" the condenser fan runs continuously (even without the ac on). I understand that the system is designed to have the AC compressor cycle off and on when the selector is in this position regardless if the ac is on or off.
I suspect there is a sensor somewhere for temp or pressure (?) that may be crapped out, but I am unsure where to locate this.
Any help would be appreciated.
Thanks FABO
I'm pretty sure A/C runs when in defrost regardless of button being pressed which would make the fan run. Is this something new? Or did you just happen to notice?
I just noticed it. IIRC, most other vehicles, the fan would cycle.....This one runs continuously when in defrost.
