8-1/4” rear gurus. Need a question answered.
Syleng1
Karma is real and Life is short...
North Franklin, CT
1984 Dodge short passenger Van B150
318/904 8-1/4” with 11” brakes
I am wondering what could the possible gearing be for the van/ pickup rear axle in this 8-1/4”.
I am not ready to open it up yet as I am not ready to tear into it. It is a one wheel peel and the drive shaft turns just under two times for the axle to rotate once. I was holding the opposite axle still.
Tags show 2.9
3.505
Does not add up.
Syleng1
Pull the cover and check. You'll want to see the condition anyway.
Gonna wait. Trying to find an 8-3/4 rear and go 3.23sg I’ve got a pumpkin just sitting here.
If I decided to keep this axle then I have a sg and gears for it as well.
Lol! All because I’m too cheap to spend for fluid and cover gasket. lol! Pinion and axle seals don’t leak- that’s one for the record books.
So I got the cover off - decided to spend some money on a gasket and new fluid.
2.94-1 ratio.
Ring gear number 2852933
Close enough to 3.0 I’m going to keep not worth the energy swapping out to go to 3.21-1 ratio. Maybe add a locker but honestly open in a street van is okay. Thanks for the help.
Syleng1
