[Found!] 74-76 column shift linkage for SB w/904
j_anderson
Fort Wayne, Indiana
Looking for a piece of the shift linkage for a 74 Dart. Small block with 904, column shifted. I have the rod that attaches the transmission lever to the torque shaft.
I need the rod that attaches from the torque shaft to the steering column.
Any idea on correct length ? Doesn't look any different than the one from my SL6 904 ?? Could measure mine for comparison if you had a measurement to compare it to.
I might be able to measure from torque shaft to steering column next time I'm at the car. May be next weekend
The rod you want is the same for 6 cylinder and 8 cylinder Abodies from 1974 thru 1976.
Chrysler calls it a front column shift control rod for automatic transmissions.
Chrysler part number: 3575361
