belt drive MSD distributors
RAYS 69 MOPAR
los angels
hi guys I wanted to see or ask if the distributor portion of the belt drives are interchangeable between engine sizes and brands ? thanks mopar or no car
Do you mean the crank pulley that drives the Alternator, water pump, AC and Power steering?
just the distributor part I know the brackets are different between different motors and what not but is the distributor portion all the same?
As long as you line-up the pulleys ad are able to set or vary the tension...you're good to use whatever you want. Now the drive pulley needs to mount unique to the engine (of course).
