The two pin ballast that I have, I don’t trust it, so tried the one side of the 4 pin. I have a new ballast coming today. I’ll try the other wire mentioned.
Without a starter relay, you have no way to get 12V when you engage the starter. That's why I recommended hot wiring it.The two pin ballast that I have, I don’t trust it, so tried the one side of the 4 pin. I have a new ballast coming today. I’ll try the other wire mentioned.
| #2 |
| dsraven Registered User Join Date: Nov 2010 Location: calgary alberta Posts: 8,317 | Re: Quick Question I usually use the permatex aviation form a gasket, the brown stuff in the can with the brush under the lid. it works pretty well on threads that are not pristinely clean. just make sure the threads go into the water jacket as you go, otherwise, if it is just a blind hole with no coolant contact, use oil on the threads just to ensure lubrication. some guys swear by the GM branded head bolt sealer. not even sure what it's called anymore. some guys swear by the newer Permatex® High Temperature Thread Sealant, which lubricates as well as seals and is intended for head bolts and other high temp uses. you could google the permatex page if you wanted to check it out https://www.permatex.com/products/th...-sealant-6-ml/ |
View attachment 1716341056 Today, 04:43 PM #2 dsraven
Registered User
Posts: 8,317Re: Quick Question
I need to pull my intake/exhaust back off to seal the studs BETTER (permatex didn't work), someone said the Remflex gasket is not re-usable? I do have one coming. But since it hasn't been ran, is it still not re-usable?If Permatex didn't seal, something's wrong. What product did you use?Good morning!I need to pull my intake/exhaust back off to seal the studs BETTER (permatex didn't work), someone said the Remflex gasket is not re-usable? I do have one coming. But since it hasn't been ran, is it still not re-usable?
The #2 doesn't work as well for that as the regular RTV. But you'll get it I'm sure.I actually was surprised that a few did leak, but it was a Permatex dark brown thick stuff. I felt I was meticulous and generous in application on the new studs bought from a member here, Badvert65, I figured I'll go ahead a remove the manifolds this afternoon~ have to meet a friend for brunch
One picture is a red flag for me.I"m always looking at seats, these are out of a Chrysler 300s front and rear for 600bucks. plus a 3 hour drive. I'm not going to buy them, just looking, but they look nice in the picture. meh Kind of dumb, this is the only picture. It doesn't cost extra on fB to put a mess of pictures.
