'65 Dart /6 A833 swap - clutch fork, input shaft, speedo gear, crossmember questions
CMKirk
Monroe, CT
Hello!
Getting ready to start an A833 OD swap into my '65 Dart 2dr /6. Ive compared the A833 to a spare 3spd tranny and bellhousing I have, and I have a few questions.
The input shaft (from the end of the bearing retainer to the end of the shaft) on the A833 is .200 shorter than the stock 3spd (see pics) All other dimensions match. Will the slightly shorter shaft create any problems?
The clutch fork for the stock 3spd uses a tab type pivot mount, while the A833 clutch fork uses a ball type pivot mount. Can I assume that I'll have to get a ball mounted clutch fork? If yes, anyone out there have one or know where to get one?
The tranny is from a '76 Volare. Is the speedometer cable mount/input the same as the Dart?
Is there a resource to figure out which speedometer gear I'll need in order to get a somewhat accurate speedometer reading?
Will I have to redrill holes in the crossmember, or fabricate a new crossmember?
Thanks...
Hello!
Thanks...
I'm in the middle of a similar project. Mine is a swap over from a 904 to an A833, however my 833 is out of a 65 A body. The big dilemma for me was getting the right bellhousing. #2468433. I tried to adapt an aluminum bellhousing, but "no-way-Jose'" way too much needed modification. My application uses the same fork as the three speed and the input shaft of the 833 poses no problems. I'm waiting now for some new pressure plate bolts I ordered to install my Zoom scalloped, 10" clutch. 1965 Barracuda tricked out 225 /6.
Norm
Norm
Norm - Thankfully I was able to get the correct bellhousing. The A833 OD takes a specific bellhousing that has a larger opening for the bearing retainer. My biggest question right now is the clutch fork...2 totally different styles.
the speedo gear, housing, attachment clip and cable are all different than the 65 stuff. everything changed in 67
check with brewers on the clutch fork or throw up a wanted ad here in the classifieds.
brewers also has a speedo chart on the site that tell you what ya need based on tire height and rear end ratio.
Hello!
In order:
Input shaft is no problem, as long as your engine was previously a stick. Some (automatic) crankshafts did not come finish machined for a pilot bearing.
Contact Brewer's Performance for the clutch fork. Also a wealth of knowledge on all things "four speed" and clutch.
No. The later trans uses a different style speedo gear and housing. You'll need a '66-'67 cable to connect the new trans to your speedometer.
Go to Mymopar.com and download the Aspen or Volare FSM and they will have a chart regarding speedo gear selection based on rear gear ratio and tire size. Many online charts are notoriously inaccurate.
No crossmember modification is needed, but you will have to modify your transmission tunnel if your car was not previously a floor shift.
Additionally, '65 transmissions/driveshafts used a "ball and trunnion" front joint, whereas your OD transmission uses a slip yoke; so you will need a different driveshaft made or modified for the new transmission.
Measure the diameter of the input shaft. I recall 65 uses a smaller pilot bushing.
Nope, not on a manual trans setup. The automatic converter hole was smaller in '67 and earlier slant's and 273's, but, not a manual pilot bushing for a manual trans crank. If you have an automatic crank that hasn't been machined for a bushing, there are conversion bearings out there that can be used. They fit in the converter hole instead of the pilot bushing hole.
You're in for some conversion mods of some sort. The OD trans has a large diameter front bearing retainer. That means it needs a bell housing with a corresponding large hole. The '65 bell housings all have a small hole, so, if you're going to use the OD slant 6 bell housing, you will have to rig up the clutch release linkage parts to fit the car. That wil require a custom bracket for the Z-bar pivot ball on the bell housing to line up with the stock one on the frame rail. Your original flywheel and clutch assembly should work ok, just match the release fork with the bell housing (and it's mounting design) you're going to use. There are other methods to skin this cat, but, I found this one to be the easiest.
And that's a fact! "Been there doing that and buying the T-shirt."
I have the correct large hole bellhousing for the transmission, but I will need a new clutch fork because the OD bellhousing has a ball pivot. Hopefully the rest of the linkage will line up. If not, I'm capable of fabricating whatever parts I might need.
I ran into this when converting my /6 64 Valiant from 3-on-tree to 65 A833 4 speed. (Keeping the B&T)
Anyway I had shifting problems as the car warmed up. Rather than stay with a new Oilite bushing in the crank, I went with the newer roller bearing style. (Incidentally Oilite bushings were invented by Chrysler engineers in the 30s)
The OD was too large so I turned it down on a lathe. It appeared to be powdered metal but machined easily. IIRC I went with a .002 press fit and it works fine.
I have only seen that ball pivot on slat six truck bell housings. I don't know if that really matters other than the ball pivot clutch fork is longer than the A-body fork. That long fork might make linkage alignment an issue.
I completed the conversion 2 weeks ago. I ended up having to find another bellhousing because the truck one would not work. Im trying to sell the truck bellhousing...
The Ball-fork to me, indicates a truck bellhousing. If you provide your casting numer to Brewers, He can verify that ...... or not.
