New Oregon cam in my 360 magnum
Evan Dutch
North Carolina
Sent the cam from my 360 magnum to Oregon cams to get ground. Installed and fiddled with the tune enough to get it to idle. Using Holley terminator X for engine management. Needs some more tuning before I can start driving it again.
Sound clip uploaded to YouTube:
Oregon Camshaft
#1990
224/230 @ 0.50
.510/ .510
112 LSA
Stock bottom end and heads. Ported kegger intake, Upgraded Hughes springs and Doug’s headers
That thing should run HARD right up to the point the kegger manifold gives up, 4900 rpm or so. You need an intake badly.
I run the same cam in my Barracuda 5.9 based engine . Mine is 222/229 though.and I have IMM prepared EQs plus 1.7 Harland Sharp rockers .
Gobs of torque ! Although I am getting valve float over 5k. I didnt realize that my heads had the beehive springs vs the doubles . I will be changing that soon .
I’ve got the upgraded magnum Hughes springs in this car
Hydraulic lifters and 1.7 rockers arms?
Didn't I see a post online that you just put a TorqStorm kit in that car?
Cool car, I like the paint.
Yep, Just finished the install a couple days ago.
Torqstorm 360 magnum
I'm starting a 5.9 build in the Dart. It's the 360/360hp crate motor that I'll be stroking to 408". Talked to Hughes, they have the stroker kits, but the camshaft is the choke point. Wouldn't even give a lead time.
I'll talk to Oregon cams about regrinding my cam. Thanks for the idea.
Oregon cams is very knowledgeable. Great people to work with. All in all it took about 3.5 weeks for the entire process. 5-7 days to ship it from the east coast out west. Then when they were done, another 5-7 days to ship it back. I want to say they charged me around $200 for the service and whatever the shipping cost.
Thanks Evan. I'm outside of Sacramento so the shipping times should be half of yours.
I'll be curious what you end up with as well. I'm working on a 408 roller cam build as well. Oregon Cams recommend a new cam for my build because he said the original cores aren't made from the best material and regrinding would grind through the flame surface hardening. Because of this, he said for any regrinds on these cores, to limit spring pressure to 110 lb seat and 300 lb open. Those are pretty soft spring pressures for a roller cam.
Maybe so and I believe Ken had said that my springs (Hughes 1110 kit) were borderline. No issues with about 2000 miles. Mild cam.
Grind is 1634 218/224 270/276 108 528/536. As I recall he did need some numbers off of the cam in order to g rind but I forget why.
Might have had something to do with surface hardening.
Can you run stock pushrods lifters and rockers with this cam
I am. I installed an adjustable pushrod to check what the lifter preload is. The lifter preload with stock valve train and stock 6.900” pushrods is .080
Seems sufficient for a roller hydraulic lifter
Oregon cams should give RRR a lifetime achievement award. I'm thinking that's over a dozen cams he's sold for them on this site alone lol
