Intake manifold options for a Magnum 5.9/360
Kern Dog
Build your car to handle.
Granite Bay CA
Forgive me, I actually did do a search on this but found nothing....which surprised be a bit.
Regardless, I'm curious about what intake manifolds are available that fit a Dodge 5.9 Magnum engine. I'm looking for a basic dual plane mid rise single 4 barrel design.
I remember this one....
....BUT while the picture shows a Magnum style vertical intake bolt setup the Magnums used, it is described as "Small Block". The price is unbelievably cheap too. Compare that to this one...
Almost FIVE hundred dollars for an intake manifold ???
the air gap and the knock off air gap are all you're gonna find new. used you can occasionally find the M1 dual plane, but it'll be about the same price as real deal air gap.
there are arguments conversations about power per $ or lack there of either way on the three of them.
Looking at the Crosswinds a bit closer....
It does look to have both bolt patterns to it.
Why the heck is it so cheap ??
yeah that's got both. and a coil mount!
that's about what the hong-kong phooey intakes run: 130ish~175ish
check 'em when you get 'em, sometimes the ports is off.
I used the ebay airgap at $127. I believe all the chinese intakes are the same. It’s pretty well made and the ports line up well. There’s one major flaw, which is that the magnum bolt holes are the LA width instead of the thinner magnum width, so the intake doesn’t line itself up when you drop the bolts in. If you aren’t careful you can end up installing it not aligned with the ports and even so far back that the distributor won’t line up. Not a big deal if you know to look out for it though. IMO it’s a very good intake for the money.
Sadly there is only those 3 dual plane intakes available for the Magnum. But those 3 have you covered.
I’d be surprised if you could find the M-1 cheap as people think they are made of gold.
The engine that I might be getting has an M1 single plane and a cam bigger than I prefer. This is the 380 HP version 360 that Mopar Performance sold for many years.
I won't be drag racing this car, I want low end and midrange power. I don't care to run it over 5500 rpms so a single plane isn't a good fit for me.
I'm sure the dual plane makes more low end torque, but the M1 single plane also does a good job down low, at least on my 380hp crate it does.
https://www.hotrod.com/articles/mopp-0303-360-crate-engine-buildup/
Tested at Westech
Mopar Performance 360 cid 380 hp rated
RPMTQHP
2500380.6181
3000402.9230
3500415.1277
4000437.8333
4100439.5343
4500437.1375
5000416.3396
5400398.6409
5500388.6407
6000343.9395
A fellow FABO member has a 360/360 in his 68 Dart....
I have driven this car. It did in fact feel soft from idle but I did not push it hard or high rpms where it may have come alive. I have a basically stock 360 in a 67 Dart that flat out rips right off idle. It has a dual plane intake and a smaller cam.
If a torque peak is at 4100 rpms, I'd call that less than optimal for a street car.
The white 68 Dart above had 3.91s and a Tremec 5 speed. My 67 has a 904 and a 4.10 gear. Just a guess but I suspect that I'd get him from a dig but he'd run me down well before the 1/8 mile.
I'm looking to use his engine but to change the intake and camshaft to shift the power curve lower.
are you doing a full boogie rebuild or just freshening up? have you selected a cam yet?
btw, your club mate is clearly a man of taste and style; i have a white 68 dart as well.
That blows my mind how they can be so cheap!
Remember you get what you pay for, so to get it "right" you may have to do some port matching and possibly even have the intake faces machined correctly. That said, people have had to do the same with Air Gaps.....so there's THAT.
We ran the dual pattern Profesional Products crosswind on a 360 LA in his 73 Duster and had no problem with port alignment on our 308 heads. Car ran 108 mph at 12.4s. Still have it but we're too far away to save you any money.
I used one on my Frankenteen build years ago. Magnum heads on an LA 318 short block. I never got to fire that engine, unfortunately, as I had to end up selling it, but the intake fit very well. Some do and some don't so it's something you have to play by ear. Same as the Edelbrocks now though.
There's a company out there who will fill the intake holes in the magnum heads and redrill the LA holes. This opens the door for any LA intake. I thought I bookmarked them but can't find it now
I have used (and am using) two of the speedmaster air gaps (chinese knock-offs). Zero issues with either. No leaks, no nothing and I used them straight from the box
The Chinese air gap copies are all very similar and are all decent for a mild or mid range Magnum or LA build.
They are listed for small blocks because a Magnum is a small block and it also fits a regular LA small block with its dual bolt patterns. As mentioned in post 16 the dual pattern Chinese intakes all have the LA style thermostat housing and location. It also has the LA angled and positioned bypass hose location. If you are running LA front accessories and water pump this should be no problem at all. If you are running Magnum front accessories without air conditioning this is no problem.
I put together a decent 360 with Magnum Edelbrock heads and a Chinese airgap. It was actually damaged engine I bought and fixed up. Long story short my plan was always to run a M1 single plane but I started out with the air gap it came with, did not get it to the track in time and then switched the M1 single plane on it. I have not fully tuned either setup yet but there was a noticably better throttle response with the Chinese air gap than with the M1 single plane. For a street application, who would complain about good throttle response.
I have a stroked version of y our motor and use an M1. These things have great torque, also when not stroked, and if you’re running a 4.10 gear maybe you’d want to consider the m1 also? Add a little cam so you don’t run out up top like you have been and you’ll have a great overall package. M1’s are available used from time to time too.
The cam I use us a 108cl 501/513 lift with 230/234. It’s fairly stout but kinda peaks around the 5500 mark anyway and I notice no performance loss using the single plane.
Good luck on this endeavour and your final choices.
Used a china magnum intake from eBay on my '97 magnum in a '73 dart. I was very impressed with the fit and finish. I tapped the boss in front by the thermostat housing and was even able to hang the original RV2 compressor on the damn thing with all the factory pulleys. I feel the engine has about the right power for an all stock 150k mile 5.9 magnum.
I have a stroked version of y our motor and use an M1. These things have great torque, also when not stroked, and if you’re running a 4.10 gear maybe you’d want to consider the m1 also? Add a little cam so you don’t run out up top like you have been and you’ll have a great overall package. M2’s are available used from time to time too.
This car I have is not a drag racer.
I only have the deep gear because I like driving it off road on trails sliding around like them Duke boys did. Driving a V8 RWD car off road is a blast....I don't want a setup that only runs hard at higher rpms.
