64 And 65 Valiant And Barracuda Front Valance Panels
RustyRatRod
Caput villa stultus
Georgia
Are the front valance panels for the 64 and 65 Valiants and Barracudas the same? Vixen's has some rust through and I need to know before I start looking for one. Thanks.
I believe that front ends are common for the Valiants and Barracudas for those years; fenders, valence and hoods...
if you look at pics of the openings you will see the difference s and Valiants may have lights in the openings. If you dont care about these minor differences you are all good.
Aren't the fenders different, too?
Regarding the space and angle between the upper and lower arms of the "V".
I can't remember if the opening in the Barracuda valance is smaller than the opening in the Valiant, but I'll go out to the shop and check when I get this little dog off my lap...lol. I know for sure that the one I'm putting on my Barracuda is off a Valiant. I had to drill out the tabs that held the turn signals. I'll take some pitchers of the 2 if they are different. I honestly can't remember if the rusty crusty one on my Barracuda is an actual Barracuda valance. Bottom line is, either one will bolt up on either car....they just look different.
1969 Motors Manual
:thumbsup:
Here’s the one I’m putting on my Barracuda. It looks identical to the one on the car. I suspect the car has a Valiant front clip on it, because the front fenders are 100% from a 65 Valiant. If you find one from a Barracuda, worst case is you’ll have to fab 2 little brackets to brace the turn signals.
they look good no matter what front end you put on them...Just an FYI as I know this is not a part's thread @RustyRatRod there is one with turn signal lights on EBAY right now...it's in PA but they are getting hard to find...it looks pretty good
Valiant and Barracuda valences are different. Valiant has parking lights inside the valence opening. Barracuda opening is partially filled (see the one for sale referenced in post #15). Originally, the filled area was painted black and was not very noticeable, but most today are just painted all body color.
Valiant valences will fit a Barracuda. I have one on mine, because they used to be more readily available than Barracuda valences. Mine was NOS. There are two tabs for the parking lights that I just folded down out of the way.
I've been through 4-5 of these valences in the 56 years I've owned the car. They will dent if you just look at them hard. My sister crunched one of them driving over a parking curb stop. When she backed up, one of the iron locating stakes caught on the lower end of the valence and bent the you-know-what out of it. The other ones we won't talk about.
New ones from the factory were already NLA by the mid-70s.
Thanks yall. This has helped greatly. I plan on getting mine off and inspecting it more closely. So far, I've not seen any more rust through except right at the front on a corner. If that's all it has, I may try to repair it and straighten the rest.
