[WANTED] Looking: 10/12 Wide Wheels with 2 1/2 to 3 1/2 BS
I assume you’re looking for lightly used for cheaper than new? Otherwise RC Comp can make them for you. I don’t have any, just providing info in case you don’t have it. Summit will let you use one of your 10% coupons if you order through them.
Summit coupon expired end of year.
Trying to find used or a deal.
Budget will not take $2,000 set of wheels that
we will only use for Head Up races a couple time a year.
I hope our paths cross again someday!
It does not matter what brand. Of course, not a heavy wheel.
When we have a heads up race, we want to change
the 13.5 x 31 Radials to 10.5 Radials. Our Dana rear end
is so narrow that when we put the 10.5 radials on with our
5 inch back spacing, they would not let us run it because there
is a rule about how far in the tires can be in from the fenderwells
in Stock/SS. It may only go on once or twice a years, when a few
hundreds are vital and you want to take a chance on spinning the
smaller tires to gain an advantage. Most in our class run the smaller
tire constantly but our car is both generally faster and much heavier than
the combinations they race. We are factored at more HP = More Weight.
Hint: The shorter the axles and tubes are in the rear end, less rotating
weight you are spinning.
I have some 12" wide Super Tricks with a 2-1/2" backspace, but they are a single pattern 5 x 5"
Those are not going to work for you with that bolt pattern. Guess they are safe for now.
Tom
Looking for 10 or 12 wide Lightweight Wheels with
2 1/2 or 3 1/2 Back Spacing and 4.5 Bolt Pattern for
our SS/KA Duster.
Good luck Tom .
No help here , but I`ve been hunting an 8 1/2'' wheel to go under my stock wheel well 68 fastback for a couple of yrs. , have 2 under it , need a pair , everything has to be perfect to run 10 1/2'' x 29'' tires in stock fender wheels that are only stretched ="in my case ".
aaaaaagain good luck
