Camshafts: What effect does increased lift have on performance?
Kern Dog
Build your car to handle.
Granite Bay CA
Lets say you have two camshafts with identical specs except the lift.
Same duration, same intake centerline, same lobe separation but one has say .480 lift and the other has .520. What does the additional lift do for performance?
A quickie Google search has evolved (or DEvolved) into experimental AI which could be good or bad, but it stated that higher lift makes more power but primarily at high rpm. It stated that torque was often negatively affected while high rpm was increased.
That seems incorrect to me as that sounds more like the effect that duration has, not lift.
The old fashioned Mopar Performance camshafts always seemed long on duration and short on lift, I assumed it was because they figured that their stuff was intended to be used in Mopar engines utilizing the stock rocker arms and that once you get much past .500 lift, the rocker arms are at the limits in terms of contact patterns on the valve stems.
Hughes Engines looked at it the opposite way. Their cams are often long on lift compared to the duration numbers.
What are your thoughts?
Generally cams with more lift should spend a higher percentage of time at higher lifts so generally should flow more air and make more power. Especially if engine starving for air, obviously it's all combo dependent.
Also, if the same springs are used, the open spring rate will be higher and the guides may need to be shorter for adequate clearance; both less good for long term reliability but it depends on your goals. Everything is a trade off.
But you cannot increase lift and have the same duration. Mathematically impossible. The extra lift increases the duration or you have an awkwardly weird ramp rate.
Well, not really. Duration is the rotation in degrees the valves are open. Lift is how far they open. Say a .450 and a .500 lift cam with the same duration are compared. The valves are open for the same length of time but they open .050 further on the .500 lift cam. And, it makes sense that they open quicker to get to the higher lift in the same amount of time.
Are you sure? Within the physical limits of the lifter system, the ramp opening rates are not fixed across the spectrum of cams are they? So if it is beneficial to your application to open the valve at a faster rate and you accept the consequences for that (spring rate, wear, reliability), you can spec a more aggressive cam lobe rate. Some cams with .500 lift and X duration look like a pointy cone, while others with a more aggressive ramp look like a Montana butte, vertical sides with a flat top. You need a roller lifter to accomplish the more aggressive acceleration rates and I'm sure that there are other limitations such as base circle diameter, lifter diameter, and such that limit the rate within a given scenario. If I'm wrong I'm wrong.
Well.......almost. Going from 1.5 to 1.6 rockers, for example adds lift, but the change in duration.......while there is negligible.
If you are lucky, someone will have dyno'd identical cams except for lift but I wouldn't hold my breath. May be the best we can do is someone will plug the numbers into Desktop Dyno for a guesstimate answer.
But the one with higher lift will spend more average time in the higher lift range then the lower lift cam and ports generally flow more at higher lifts.
Eg. low range 0-.250 higher range .251 - .500 which cam is gonna spend more average time at the higher lift range .500 vs .550 ?
And if your ports flow the same at .450 as .500+ what are you gaining with the extra stress and clearance issues.
What if the head flows the same at .450 and .600?
You still lift the valve to .600 because you lift average the flow.
Unless you are a street car guy. Then performance doesn’t really matter as long as it sounds cool.
Ramp rates are wildly different for tons of cams, even just flat tappet cams, in the case of Mopar's(AMC & some older Olds) the large tappet diameter allows for crazy ramp rates, it's even more ridiculous for mushroom tappets. You can 100% have much higher lifts with the same seat-to-seat duration, the question is how much You want to push it, & do You want to do/spend the $$$$ what's needed to upgrade the valvetrain.
The amount of benefit depends on the heads & what range of operation You're talking about. Take stock SB X/J/U heads, they pretty much nose-over @.475" lift, some less than others. Increasing the lift still gets the valve open quicker & spends more time in the lift range where the heads are flowing more, even if it doesn't flow much or any more at the peak, as long as the head doesn't 'back-up' dramatically it's still a win.
Possibly more average flow.
If the heads flows the same at .450+ a .450 cam spends almost zero time at peak flow where as a .500 cam will get to peak faster and spend more time in peak flow, is it worth it ? depends on the build goals person etc..
Let’s say you have two camshafts with identical specs except the lift.
The MP cams are designed in a certain parameter of thoughts which I find accurate in their description of balancing the track performance with still be streetable.
The key to this camshaft thinking is how the engine responds to the camshaft in making power and where you want to make the best and most power for your particular situation.
Duration allows more or less air and fuel into the cylinder with the cylinder head (only the cylinder head for this exercise) being the limiting factor.
Now for say, the cylinder head flows well to only .500 lift. More lift has the flow rate tank badly. Here, you don’t need more lift, so finding more power comes with duration. Holding the valve open longer allowing more air and fuel. But we know this raises the rpm level of performance and can be a draw back to the track being raced among many things.
Now! If the cylinder head flows really well to, let’s say .750. Lifting the valve up higher to get into the superior air flow characteristics of the cylinder head will allow more air and fuel to get in thus creating more power. Obviously.
Being that the duration hasn’t changed, the operating rpm range really doesn’t change much. It will rise some but the bulk of power remains the same in the same area but just with superior high end power being made. There should actually be an increase of power everywhere as in a broader and fatter power curve.
A slight loss of torque will happen. This has been seen before. Someone above wished for this test and it has happened before.
To continue my answer, I will also address the below quote:
Not exactly true. The duration and lobe of the cams opening and closing points are not changed but what changes is the area under the curve gets fatter. The valve rises quicker and higher to stay within the opening & closing points. The cam lift becomes quicker which equals more aggressive.
A quicker opening valve almost always equals more power. There is a point that you can open the valve to quickly to take wastage of what it can/could offer. Mostly, it’s a intake track issue that won’t allow the air and fuel in generously quick enough to match the valve action.
This is also why you can see/read at the Hughes web site on how the intake track (intake manifold) should flow more than the cylinder head. IIRC, Hughes wrote something along the lines of greater than 15% better. Probably higher. I’d go higher if possible. (Often it is not.)
Ok, let’s go back to the cylinder head that kicks *** with great flow to .750 and beyond with an intake and carb set up, up to task.
Lift will directly effect HP.
Crap head and intake.
Lift doesn’t help anything. Will probably just simply hurt the engine and/or combo.
The old saying of you just can’t get THERE from HERE Iis due to the equivalent of everyone driving their car at 90 and maintaining speed as you neck down from an 6 la e interstate hwy to a one lane exit.
It’s just not happening. Everyone gets jammed up.
This is kind of where the low lift cams come into play very well. While I normally suggest getting as much lift as possible , sometimes this possible is limited to a stock head.
A stock 340/360 head flows around 210 cfm @ .520 lift on the intake.
(Just for argument sake)
Then simply get a cam that lifts the valve up to a maximum.500/.520, then hold it there for as long as possible (duration) to allow the most A&F to get in.
Most stock, as cast OEM heads, will flow well to about .500. In general, the valve job is responsible for lifts to 400-450 area. After that, look at the under valve area.
If you happen to have an old MP engines book, they don’t recommend a (bowl) ported head (340/360 engines) until you want to achieve ET’s in the lower 12 second range. The bowl ported head gets coupled with the MP mechanical cam, 284/.528.
This doesn’t mean you NEED a bowl ported head to run low 12’s, it’s just a better more efficient way rather than tax the head with more lift and/or using more duration with low lift.
I hope that wasn’t to confusing and answered your question.
Exactly!
Exactly!
Open that valve up as quick as possible and as high as the head is efficient and you will have taken advantage of the head and maximize it potential.
If you follow this general rule, you will have, even with very little experience, maximized the combo for the best results without getting your head twisted into knots slicing and dicing your brains into a mush for the best possible outcome.
There are thought patterns for lifting the valve beyond the heads ability and even using the cams opening ramp to launch the valve (NASCAR) off the ramp…. While all of this is great, it’s not what should be done on a street vehicle. It makes me sense.
If the head flow great to .500, just lift the valve to .500.
No need to go crazy.
Show us an example of head flow the same at .400 and .600. I swear, I'm gonna send your wife a new baseball bat cause she musta lost the last one.
I know its all in fun but there seems to be over analysis these days.
I think maybe people think there's some secret to unlocking a lot of power and there's just not. If you make smart part choices, you'll be choosing a good cam for your given combo. So there's really no point. .......maybe other than discussion and that's cool too.
LOL! I thought you were the square lobes guy. A lot goes into cam lobes and the spring pressures to control the motion. I never talk racing stuff, unless someone posts something real stupid. It does not interest me. I am a street guy that wants a fast car and only want to do it once, not have to dork with it for a long time and many, many miles. I don't care how an engine sounds as long as it will wind up and be fast. A race car is a completely different animal. What you are talking about is picking a lobe with the best area. The lobes are always a compromise.
