Right now I have a 35 shooter, went up from a 31 that came stock. Still have the stock white cam.
The stumble happens when I'm off the throttle and quickly get into it. For the most part, if I'm already down on the throttle a tiny bit and I quickly press it, it revs up with a very slight hesitation. If I'm fully off the throttle and I smash the gas it cuts out and then goes.
Doing Dominos, I can get a lot of different scenarios knocked out in a short span of time which I guess is useful to a point lol. If I ease into the throttle it doesn't hiccup at all, it's just anytime I remotely quickly get into the gas.
I think it's difficult to get that pump shot figured out because it's a relatively light truck with a really short first gear, and a bunch of torque so it gets moving quickly. If I was to try to fully open the primaries and try to get moving fast, I guess the best way to describe what the engine sounds like is puh-WAHHHH *shift* puh-WAHHHHH. (The "puh" being a cutout lol, it throws you forward into the wheel and the nose drops, then the other circuits catch up and then it throws you backward into the seat)
