What exactly does the switch in this picture do? It’s listed as an AC-Heater Blower switch. I am assuming that when the AC door opens or closes, that it flips the fan blower to high when either you push the defrost or Max AC?I took one for the team 40 deg in the garage 30 outside.
Climb on a ladder
This is a 67 dart AC
View attachment 1716358923View attachment 1716358924
I have gotten a replacement AC housing that has the AC flapper door that I am missing in mine. But this housing doesn’t have the holes for that switch, and there doesn’t seem to be a lever or anything to flip that switch back and forth. I’m wondering that if on different years or models it’s set up differently or can go somewhere else.
I guess I can fabricate some sort of lever to activate that switch too, or I’m wondering if I even need it. I can adjust the fan speed manually.
