Before Pittsburghracer passed we had talked about rocker oiling. He posted some pictures of how he does it.
I now have some pictures of how I do it. Slightly different than John did it but it’s close to the same.
Of course, I can’t find the thread where he posted the pictures to compare them, but you can see what I do IF I want full time oil to the rockers. And if you don’t want to feed the rockers off of oil that should be going to the connecting rods.
Here you can see I’ve drilled and tapped an 1/8th pipe hole in the vertical oil feed to the pressure gauge. I use #4 AN fittings and push lock hose.
In this picture you can see I drilled and tapped the oil feeds to the head. What you can’t see is when I installed the cam bearings, I clocked the two and four bearings so that there is no hole open to the feed from the main bearing or to the oil feed to the heads.
Once the bearings are in, I drill a 9/32 hole up through the block from the main bearing side up through the cam bearings. If you look close you’ll notice I also drilled up through the bearing and the block. I then tapped that hole 5/16. I’ll explain that in a bit. Make DAMN SURE you deburr the bearings.
If you do not clock and redrill the bearings you will have oil coming off the mains and from your feed hose.
One of the goals of this is to stop feeding the rockers from oil off the main bearings. That’s oil that should be going to the connecting rods.
Once the holes are drilled, you can make up your hoses as shown in the pictures. I use hose because this stuff moves around and I’m not a fan of hard lines in a place like this.
Since the cam bearings are clocked so no holes line up either for the feed from the main bearing or the feed to the heads, the hoses supply all the oil to the rockers ALL THE TIME. You MUST install a restricters in the system somewhere, especially if you have needle bearing rockers. In fact most rockers want and need a restriction but needle bearing rockers need less oil than a bushed or plain aluminum rocker will need.
When I install the restricters in my stuff I’ll take some pictures and post them.
I have a length of 2 inch by 3/16 aluminum that will be bolted down at the two and four cam bearings. That way, any oil slinging off the cam lobes will hit the aluminum and stay on the cam.
If you look close you’ll can see Chrysler left two openings between the lifters that lets oil go back to the pan.
I’m going to use a two part epoxy or some splash zone to fill those up so no oil can get through them.
Once they are blocked off the oil either has to stack up in the lifter valley until it will go into the timing cover or it must go to the rear and get to the sump there.
Once the oil finds its level it will always be there.
That’s what I do if I want full time oil to the rockers.
Also, this block has been tubed on the passenger side so the oil is blocked off to the lifters. The drivers side is blocked off by a 5/16 set screw under the number one main bearings. Again, this stops the leaks at the lifters and that makes more oil available to the mains and rods.
Also note that I used the vertical oil feed to the oil pressure gauge to feed the rockers. I could have picked the oil up from the passenger side lifter gallery but that is still taking oil that should be going to the rods.
The other reason for using that gallery is because I know if I have 40 pounds on the gauge I’ll have 40 pounds or very close to it at the rockers.
The way Chrysler did it, the rockers suck hind tit and get oil last. I put a gauge on the rocker shafts a long time ago and you’d see almost no oil pressure at the rockers at idle. That’s bad.
That’s how I get full time oil to the rockers and limit the oil leaks at the lifters and force as much of the oil as I can to go to the bearings.
Edit: if you are not comfortable drilling holes in places as above, get a scrap block and practice up until you get good and comfortable.
You can jack up a block right quick. This particular block is an X block and even I got a bit sweaty drilling and tapping an expensive block.
If you dick up the block it’s damn hard and near impossible to fix so practice up on junk blocks first.
