Mildly successful day, helped out a Mopar guy
67Dart273
Idaho
Fairly new guy here, C.Galloway, trying to get his slant 71 A body fired after a long sleep. Screwed up last night, fell asleep in my chair and woke up a t ONE AM new time, got up at 6, so not much sleep, LOL. Went out to his place about 9:30 and got home about 2:30. Compression was low, either the long nap dried things out, or maybe got washed out. Squirted some oil in the holes, he had new plugs, and there were recent cap/ wires. Points were fried. Replaced points/ condenser and THAT went WAY better than I could have hoped. "Guessed" at the points gap and plugged 'er into the latest military supaw doopaw dwell tach and the dwell was RIGHT ON
Next, the previous owner had had big trouble with the fuse link/ red ammeter circuit, had stuffed some wires through a grommet,added a twenty amp fuse, which the current owner had replaced with a 30--it later blew, LOL. BUT THE BIG THING is the ign2 bypass circuit was not working. I still don't know why. I pulled the bulkhead connector ign harness off, checked continuity to the coil, and it may have been corroded right there, because it magically started working.
The carb (I think) still needs work, but it starts and idles pretty well, engine sounds good with no rattles, clanks, etc.
"We'll see' Chancy is gonna have a shot at the carb
I took a nap tonight about an hour, and hope I can kill the time lag by tomorrow or next day.
The meter. Bought this, made by Simpson for the military, and it will also handle the outboards. 2/4 stroke, and in reality will do anything from 1 cylinder to ??? The one scale is in percentage instead of degrees. This means if you have something that's oddball, you can "figure" the percentage and use that scale.
You are the man :thumbsup: thank you for jumping in and helping out a fellow mopar person, I feel like you realy enjoyed your time there and figuring this out, if I get board it seems working on things I know about, I enjoy it :lol: even though it's very hard on our bodies and brain, wait !! most likely good for our brain wouldn't you think Del
It is your generation of knowledge disappearing that will forever be missed in our hobby. You can't learn this stuff overnight, it takes a lifetime of experience.
Good on you for helping him out. The sequence you went through would stop most of us short of success.
Cool stuff, Del! I like that meter, too!
That is truly a HEAVY duty piece!!! I bought it mostly for the outboards. The tach has two ranges, up to 5K which is not high enough for some of the outboards. But the circuit is fairly simple and I believe I an add a switch to make it 5K / 10K.
Haven't seen one of those for years, actually in the Air Force. Been retired from there for 24 now. Definately did more then I knew how to do back then! Those will be around after most of us arent!
What did you in the AF? I was a Navy electronics tech, and maintained GCA RADAR and TACAN, ended up at NAS Miramar supposed to be 2 years, ended up 4, to the end of my 6 year hitch.
Was in Trans Sqdrn whole time, except 11 months 1st Sgt. Started in Vehicle Maint, then Vehicle Ops, then Traffic Managment... "We Move the World"
Anything on base that moved, vehicles, Personel, Pallets, Aircraft, we took care of it. Most satisfying was Vehicle Maint. Went TDY for 1st 12 years 5-8 months, out of most years.
