Brandenthepilot
Member
Wondering if anyone can guide me on the proper set up here. Yesterday start having smoking (or steam?) coming from the oil breather you can see it in the video.
The PVC valve is on the driver side cover, when I pulled the valve and only stuck the hose back into the grommet the smoke stopped and seemed to run fine. I put the valve back on and the issue started again. Ran to the store and picked up a brand new valve, and the same Issue persisted.
The current set up if you cant make it out in the pictures, is just an air cleaner, the PVC valve is on the drivers side which the hose runs to the passenger side of the carburetor.
If you have a more efficient set up please let me know. Or if there’s a better pvc valve to use than just the basic plastic one. Thank you
