Spindle tightening spec question
like_A_pike
that's not factory
Western WA
This might be the first time I have ever used a torque wrench on the hub nut. I noticed that the wheel has a little bit of resistance at 55’lbs. is that normal?
I usually just tighten it far enough to get the cotter pin in. Am I lucky to be alive or just messing up bearings by not seating them correctly?
Thanks
Oh 1968 Barracuda with ‘73 spindles (& I’m using a ‘68 manual) didn’t think of that???!!
It is smooth after that but it takes a couple pounds of effort to make it (the rotor) turn with one hand.
Per the 1973 service manual
Adjustment
(1) Tighten adjusting nut to 240-300 inch-pounds
while rotating wheel. Stop rotation and back off the
adjusting nut with wrench, to completely release
bearing preload. Next, finger tighten adjusting nut
and install lock nut (Fig. 10) with cotter pin. The resulting
adjustment should be .0001-.003 inch end play.
(2) Clean grease cap, coat inside with wheel bearing
lubricant (DO NOT FILL) and install.
(3) Install wheel covers and lower vehicle to floor.
Another poster mentioned that that’s 20’ lbs! I think I’ve over done it a bunch
1968 manual. I backed them out and seem ok.
I NEVER preload wheel bearings. Hand tighten the spindle nut only. You can tighten the nut SLIGHTLY more if you're really close to getting the cotter pin in, but, that's it. I've been doing that for over 50 years now and have never had to replace a wheel bearing on any of my dozens of vehicles I've owned.
300 inch pounds (which is the correct spec posted above) is 25 foot pounds, so you have the spindle nut TWICE as tight as it should be. Also, they must have some preload, as the FSM states.
The proper procedure is right there in the FSM. The tightening spec is not the final tightening spec, it’s just to seat the bearings in the proper spot. Then the spindle nut gets backed off completely, and then finger tightened so that the cotter pin can be inserted.
The final spec is just .001-.003” of end play, with the nut finger tightened. That indicates no preload at all, because there is still end play.
I found your post from an 8 yo thread (w reference to a’73 manual) thanks x2 I guess
my car is a ‘68 and I only use/have the FSM for that. Not helpful when your spindle is a’73 and in ‘68 it says crank that nut to 55’lb! Didn’t occur to me until after!
It shouldn’t really be an issue unless you drove the car around with the spindle nuts tightened like that. That initial spec, regardless of what year spindle/brake set up you have, is just for seating the bearings. Everything for a ‘68 would get tightened and then backed off completely just like the 73+ stuff. For that matter, any spindle/brake set up using tapered wheel bearings pretty much follows the same procedure.
Same reason it tells you to fill the hub between bearings with grease. So when shat gets hot that grease keeps the bearings lubed. Also keeps the cap from rusting from the inside out...
Better to be a bit tight than to be too loose.
Too loose you may pound the bearings out early. Too tight you may seize the thing and snap off the spindle or cause the wheel to slide with, uh, "interesting" results
