A Body Leaf Spring Relocation Kit With Sliders
BergmanAutoCraft
FABO Vendor
FABO Vendor
Hampstead, NC
Hey everyone. We just finished up our offset spring hanger kit with the first every, bolt in slider assembly. This is similar in offset of prior discontinued Direct Connection kit that moves the spring inboard .5" even with the inner wheelhouse. I have run 275 tires on a 18x9 rim with this setup. Our kit offers many upgrades in that its a complete kit. It includes specific fit spring pads, delrin bushings for the leafs, front and rear. The front hangers have 2 positions and features countersunk hardware, so no frame clearancing necessary. The real feature is a bolt in slider assembly that completely replaces the shackles. This assembly is not the generic unit sold elsewhere. It operates silently and offers a tremendous amount to stability you can feel, no matter the usage. Larger tires can now be used as the lateral motion of the spring has been reduced so much. On sale now and in stock. Click the link for more information.
Any chance you'll be selling the slider bracket separately? I'm sure there's folks out there with doctordiff and MP offset kits already installed that would like to have the rear sliders...
Any B/E options in the works?
Am I looking at this correctly that it requires this bracket to be removed in order to get that bolt out and adjust the ride height position?
Peter, I know you drive your car hard, how do you anticipate the bearings holding up on an auto cross/road race set up?
These look very similar to the Dr. Diffs front hangers, After installing several Dr Diffs and Mopar Performance versions over the last decade, I'll take the drop the front bracket to adjust the front spring eye location anyday versus the frame cut out required for the inside nut on the Mopar Performance versions. If I remember right, I was thinking the thru bolt on the Mopar Performance hangers was too long to remove from the outside anyway.
it's an observation.
Good evening, Peter I would also be interested in purchasing the sliders separately.
100% ....I'm was kinda wondering what others have experienced installing the different versions and which style they do or would prefer?
Very cool! Just to clarify when you say " I have run 275 tires on a 18x9 rim with this setup" what vehicle are you talking about? I have a 68 Dart with stock wheel wells. I would like to run 275 60 15 on an 8 inch rim. is this doable with this kit? thanks!
Right now, no. B/e in the future.
D
Dr. Diff didn’t manufacture those brackets…
