I learned something new today while I was trying to educate myself more on alignment as I have always left this to others. I found this video. It looks like he sets the upper control arms for max caster and then shims the lower ball joint to get his camber:
I thought some discussion might be 'interesting' although I see it has been discussed a little in the past. Is it looked down upon for the street? Failure of the bolts would obviously be catastrophic.
Unfortunately I didn't know about the Moog offset upper control arm bushings when I bought all my parts from PST. My understanding is that the stock design is limited on caster adjustment. I was thinking shimming might be a good way of maintaining caster if I find that I have to move the rear control arm can a lot to dial in the camber (hopefully my understanding of this all isn't flawed). Perhaps it won't be an issue. Its just a thought....maybe a bad one
