TheLeftybar
Member
Hello, new to the forum and I hope my Truck is allowed on the forum. I have a 1988 Dodge Dakota Sport with a 3.9L LA V6, Torqueflite A998 3 Speed Auto Transmission, and NP231 Transfer Case. I recently got done with a transmission rebuild on the truck after having major leaking & shifting problems. After putting it back together and test driving it, I came up on a major issue and have been struggling to figure out how to fix it. So to help, here are some details on what happens during the rebuild and what's going on.
Me & father planned on installing shift kit but didn't happen cause he wasn't comfortable installing it, ended up setting line pressure to 70psi by accident and wouldn't let truck really shift into 3rd but I lowered it down to 60psi. My father also broke an E-clip for the governor (big man, lil parts) and I ended up getting two thinner E-clips from Bomgars and doubling up (the two were thicker than the original but were talking like a couple thousandths of an inch thicker).
Now the line pressure is at 60psi and "3rd gear is back." When WOT, the transmission won't shift up 2 to 3 and rev up all the way to 65mph (should shift at around 55-60mph) until you let off the throttle, then it'll shift. Then when your driving and you hit about 70mph, the truck then for some reason proceeds to downshift 3 to 2 and rev the hell out of the motor.
I'm thinking I need to lower line pressure until it's about 54psi and adjust the kickdown band again but other than that, I dont know what would be causing this and I would like some feedback.
