[WANTED] WANTED-GOOD USED FEDERAL POWER STEERING PUMP
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
Looking for a good working used, and non leaking Federal power steering pump. Should have pn 2557955. The pump on my 71 Demon appears to be over assisting, so I want to swap in a replacement. Mounting brackets not needed. Please reply with PM.
Thanks FABO
Thanks for the pics Dave. That is a Saginaw pump. I am hoping to test the pressures tomorrow to confirm that I don't have a box problem. I may end up converting to the Saginaw system, so I will keep you posted.
Any, idea what the pump number crosses to? The later Saginaws use metric threads.
