Ironmike
I guess this is really a follow up from a post I made last year. Was running really rich at any cruise speed and ok at WOT. Took everyone's advice and did some surgery. Here's what I did and where I am now.
The T-slot restrictors from factory where huge. I have them at .062 now, all four corners. That helped a lot. Was a little lean during brisk acceleration(front barrels only). So... next I opened up the power valve restrictors up front to .077. I run 2 4.5 power valves. Helped a bit.
Next I put on a 1/2 inch HVHS Supersucker and drove it around for about a hour today. Plugs look exactly like I would want ..............on the passenger bank. Drivers side maybe a bit too lean. Almost new looking.
At WOT, it's hard to watch the A/F gauge but I got a glimpse of it and it appears lean-ish. 2nd gear nearing redline(6800) I saw 14 to 1. BUT again, that thing will rev so friggin fast I'm on the rev limiter in the blink of an eye.
So now I am much better cruising(13ish to 1) but not perfect. WOT a bit lean. Drivers side leaner that pass side.
Here's the set up: 78 jets up front. 86 in the back
37 MAB's up front. 34 in the back
And the real kicker is 4.5 P valves both up front AND in the back. I know with P valves your jetting should be square, but that aint gonna work
I'm thinking I should open up the secondary PVRC as I did with the front. That should get me richer at WOT. ......i think.
How can I get the passenger bank a bit more fuel, without enrichening my cruise AFR?
Smaller MAB on that side? Bigger jet on that side? Sounds crazy, but I saw Holdener do it on the dyno once.
I have done nothing to the emulsion circuit on the metering blocks, which are many. It's ridiculous that Holley did that, but I have no clue how to correct it, if it even needs correcting.
So, this is a lot to digest, I know, but I'm sooo close!
