The mighty 318! Help with compression, and head/piston combos…or even a stroker!
If it's the same guy that was doing the machine work with the Mag drill and the "bansaw" I am sure he plans to do the crankshaft himself too.
I wonder how he's going to offset grind the crankshaft down .690" to get his 4.00" stroke? Because you know he's not going to buy one with all of his talent.
Tom
Tom
So threads with good argumentative discussion where actual knowledge and experience is contested and shared get locked and absolute garbage like this is allowed to continue.
Got it.
only problem with this build is you cant get them heads any more, but close to my build, im using home ported magnums and another to big of a comp hydraulic roller cam....
I found this.
