Duster's next. Been sitting for 2 years. You can spell your name and play tic tac toe in the dust(er) lol. Time to drop the ET just a little...
Just ordered a 40 tooth gear to keep the speedometer correct...Awesome! Any teases on the plan?
Be well,
Pat
another engine will most likely end up under the hood, but not the 440. 440 has a destination, and I think you know where that is...440 !!
we'll get it back to the track this year to hopefully make a faster pass, but most likely all the changes won't happen by this race season's end.Looking forward to it.
Still looking forward to itwe'll get it back to the track to hopefully make a faster pass this year, but most likely all the changes won't happen by this race season's end.
Sold the '74. Still have the '76, and plan on keeping it.I thought you sold that duster?
Hopefully not some lame small block stroker.another engine will most likely end up under the hood
That was on the agenda a couple years back for Drag Truck. Had all the fix'ns in the cart. Changed my mind... lolTURBO SMALLBLOCK!!!!!
LOL.... you gonna swat the bee hive then run?? That would cost a little money and you know I spend my money at restaurants , not go fast parts..Hopefully not some lame small block stroker.
Nope, I'll be right here. lolLOL.... you gonna swat the bee hive then run??
First post... "Time to drop the ET just a little" ... lolNope, I'll be right here. lol
I figure if you're gonna stray from stock cubes, you may as well go big and get the biggest bore available and start with a 400 block.
I mean it's power you're looking for, right
Good luck 2 ya. KimTimes to beat are 8.19 in the 1/8 and 12.8's in the 1/4. At least that's what it went last time out 2 years ago. Pretty easy to drop the ET when everything is basically stock.... LOL.
I see a cam change in your future.Pretty easy to drop the ET when everything is basically stock..
