Now THATS a ground! Interesting that picture shows the original green underneath the respray your FIL did when he originally built the car. Neat!Here is the new voltage regulator that I rewired. I also ensured it had a good ground and added an extra ground wire.
haven't had the car out???....heck, I have not had either car, the HemiDuster or the Flash even out of winter storage. It has been an interesting 6 months to say the least, but I am gonna take a break and head to Carlisle shortly. I will look you up for a little BS time.
Denny
That will be great to see you there Denny! I will be in section R155 on the show field between gates 2 and 3………![]()
You can't go wrong with the stock one. Those chrome ones usually leak.The chrome thermostat housing was leaking. After trying to fix it with some gasket sealant, it still wasn't good and looked terrible.
I went through my old parts and retrieved the original cast-iron one that was on the car. Hit it with the bead blaster, high heat primer, and high heat paint, new gasket, and no leaks. Plus, I think it looks better.
