What distributor y'all lovin these days?
ValiantKevin
Kansas
So there's nothing I hate more than breaking down and even worse, breaking down because of shotty ignition...
With a lil research it looks like all kinds of decent electronic distributors are out there but who can I trust?
I am liking Mancini's electronic distributor kit, or do I just stick a pertronics in the OEM distributor and send it?
I like the Petronics conversion in a street car that does
not go over 5500 RPMs.
In our street/strip cars I run the old analog
MSD 6 AL and a MSD Distributor.
I bought the Mancini MRE version with their orange box ECU. Worked fine on the test stand which is as far as I have got with it.
Look for a 3690430 unit. They're out there for a reasonable price and superior to anything made other than the 3/400 units.
Can you do not just a 318 Dakota pan.
We modify the steering to us the Dakota pan
on our A body cars. They are the best production
Mopar pan for HP in our testing.
I installed a complete MSD system about 6 years ago; MSD box, non-vacuum advance MSD distributor, MSD coil and MSD wires. It runs very well. Plus, it starts much easier/faster and idles better now.
Nothing wrong with the factory dist except:
[1] Vac adv has been hooked up
[2] Has high mileage.
The VA unit moves the p/up wires EVERY time it operates, which flexes the wires & eventually they break.
At a most inconvenient time.....
Get a new p/up for the stock dist & good to go. Check operation of the VA unit.
I was planning on going with the FBO ignition, then after I did some research I decided to go with a coil near plug setup. Holley makes the whole kit.
Eight coilpacks give more time to charge. Better consistency across the rpm range.
You can go with a crank or cam trigger.
I think you posted an answer to the wrong thread John. This thread is about distributors. :thumbsup:
Tom
What controls the timing? Do you also need one of the Holley ecu?
You can go with a cam timer, there's a replacement for the dizzy that you drop in. There is also a computer, so you can program your ignition timing.
My plans are to stay with carburetors, but their system does tie in with injection.
