Duster2022!
What is a good size torsion bar to use in a 440 Abody swap? Running 440
I’m doing a big block swap into my barracuda that originally came with a 273 but someone changed a 360. And because my 383/435 has aluminum heads aluminum intake, aluminum water pump I am using the factory torsion bars. My big Block weighs the same as the 360 that I took out. Not sure what size motor you had in your car prior to the 440.What is a good size torsion bar to use in a 440 Abody swap? Running 440
I bought it without motor, but I think it was a small block carI’m doing a big block swap into my barracuda that originally came with a 273 but someone changed a 360. And because my 383/435 has aluminum heads aluminum intake, aluminum water pump I am using the factory torsion bars. My big Block weighs the same as the 360 that I took out. Not sure what size motor you had in your car prior to the 440.
You can take the torsion bars and look at the bottom and see what the number is off the top of my head mine are 871and 872 something like that. And you can look those numbers up and it’ll tell you what motor they supported. You can run six cylinder torsion bars if you’re going to race it. But basically it comes down to how you want the car to handle.I bought it without motor, but I think it was a small block car
Just a street car, maybe down the track once in awhilewhats the intended use of the car? if it were mine i'd go atleast 1.08 and maybe larger.
So these will handle good with that big block in there?then i say atleast 1.08 bars.. you'll like the larger bars. need good shocks too though.
The other thing to look for is shipping expenses. Only PST has free ground shipping. BAC has free shipping for purchases over $1K. Those bars are heavy so shipping might be too!I just looked for who has what and prices prices as I am looking.
Surprised a little, had no idea how much.
Mancini 1.03 $379
PST 1.03 $399
Bergman 1.08 $549
FIVE hundred dollars for a pair of torsion bars is a butt rape.
I used big block bars in my Duster. I had a low deck 512 with aluminum heads. I also used a big anti-sway bar and Koni shocks. That combo worked great.What is a good size torsion bar to use in a 440 Abody swap? Running 440
